Throttle Position Sensor question 22RE
Old May 5, 2004 | 06:43 PM
evanw66's Avatar
Right now I've got a '92 truck with the 22RE. It runs and drives great, but has a really rough idle. I've done all the tune-up stuff with no change in idle quality. Check Engine light is not on.
Out of desperation, I began unplugging EFI input sensors to see if that would lead me anywhere. When I unplugged the TPS, the idle got TONS better. Still a slight hitch to it, but the engine is no longer shaking like it was.
So, I feel pretty confident that this means I need a new TPS. But Toyota wants about $100 for the sensor, so I thought I'd ask for confirmation here before ordering a new one.
Any help is appreciated.
Thanks!
Old May 5, 2004 | 08:58 PM
SoCal4Running's Avatar
Without verifiying the computer code (if there is on) I would not spend $100.00 on a TPS.
Its does sound like a TPS issue but may just need adjustment.
Also check for air leaks at all hose connections and the tube that goes from the airbox to the throttle body.
Old May 6, 2004 | 05:08 AM
PirateFins's Avatar
Thanks!
Couple of things to try. 1st Clean out your throttle body Throttle Body Cleaning link and intake really good. The TB cleaning link is for a V6 but the principle is the same. You can follow the instructions on a product some of us have used in this link Intake cleaning with sea foam Post #14 is where Mohamed outlines how he did it. I have used it also and it works well.
After you get the intake clean if you are stiil having problems try to adjust the TPS, use the link below for instructions.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old May 6, 2004 | 08:50 PM
evanw66's Avatar
Thanks for the links - I'll give the cleaning and adjustment a try.
Thanks again!
Old May 7, 2004 | 03:03 AM
foxtrapper's Avatar
Guest
Thanks again!
Also, clean the TPS itself. Many times they get gunked up and fail to properly spring back to the idle position. A quick shot of carburetor cleaner into them and flicking it back and forth with the finger yields great results.
Old May 7, 2004 | 10:31 PM
Phoenix12's Avatar
I have a brand new TPS I bought for my 97 4runner, but don't need it now. Check engine light came on then went off the day I bought the thing. Don't know if it fits yours, but if you need it and it will fit, let me know. I'll take $50 to get rid of it!
Old May 7, 2004 | 11:47 PM
amusement's Avatar
Phoenix your TPS wouldn't fit. Sorry.
When you disconnect the throttle position sensor this what happened;
the ecu sensed the TPS failure and went into limp mode
- limp mode allows the ecu to fudge on managing EFI to allow you to get home
it is meant to be a very short term
- suggest pulling codes out of the ecu even though there's isn't a light
- get a multimeter and begin to test the TPS for faults
- TPS may not be the fault ... Mass air sensor, oxygen sensor, coolant sensor could have a problem.
Old May 8, 2004 | 07:36 PM
grafix43's Avatar
if your engine is shaking alot and u have a very rough idle, you could possible have bad compression in one of your cylinders ..... i would suggest getting your compression checked, being a 92 you might need a valve adjust depending on the mileage of your car... i just got my valves adjusted and my car sounded like u are describing but now all that is gone....
kazuya2416
Apr 5, 2024 02:17 AM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
