Throttle Cable Adjustment
Old Mar 20, 2003 | 04:38 PM
03TundraTRD's Avatar
I check out my throttle body and on full throttle it dose not open all the just half way i there any way for me to adjust the cable.
BTW I have a 2003 Tundra V6
Old Mar 20, 2003 | 04:58 PM
joez's Avatar
remeber, the cable only moves the throtle 1/4 turn. if it turned it any more, it would begin to close.
Old Mar 20, 2003 | 06:27 PM
FattyCBR's Avatar
Re: Throttle Cable Adjustment
Joeyz is right that the throttle plate only turn 90˚ to open fully, but if you want to adjust it:
You should see on top of the plenum the throttle cable is held by piece of metal with a nut on each side. If you tighten the nut (clockwise) closest to the throttle body (you'll need to loosen the other side first) you will loosen the throttle cable. If you tighten (CW) the furthest nut you will tighten the throttle cable. Just make sure you are tightening the throttle cable and not the transmission kickdown cable.
Old Mar 21, 2003 | 09:06 AM
Good Times's Avatar
03TundraTRD:
Not sure where I read this but I do remember something about Toyota buildling the TB plate that way. Something about at WOT, it's not fully open. I think if you do a search here you'll find a reason why they don't open 100% at WOT.
If it's not here then it's on 4x4wire...
gl
Old Mar 21, 2003 | 04:20 PM
I know that the plate in the TB opens only 90 degrees but mine only opens 45 Degrees
Old Mar 23, 2003 | 02:51 AM
Also in the trucks befor 2003 there are two cables but in my 2003 Truck there is only one which cable is the other and why am I missing it
Old Aug 29, 2006 | 09:09 PM
SoCal80's Avatar
Sorry to bring up such old thread but was wondering if this works for 86 4 runner? My throttle cable is very loose. Lots of play in it. When I step on the gas pedal it takes a while before it actually starts to rev up the engine. Does the cable need to be adjusted or just replaced?
Thanks
kazuya2416
Apr 5, 2024 02:17 AM
SolarImages
Aug 30, 2015 09:28 AM
SolarImages
Aug 17, 2015 10:28 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
rbh261
Jul 13, 2015 12:04 PM
