TCU check
Old Aug 25, 2003 | 05:22 PM
dropcivic's Avatar
TCU check
I think i have narrowed down my tranny problems. Do 4runners have seperate TCUs or are they intgrated into the computers? Another question is how do i run a check on the TCU? My 4runner won't shift to overdrive and when it does(very rarely) it stays there for mabye a mile or two then kicks back down for no reason.
Thanks for the advice again.
Old Aug 25, 2003 | 06:43 PM
Gadget's Avatar
The pre 96 used separate engine and transmission control units. 96 and on have a single control unit.
You can get a factory shop manual and look up the problem in the diagnostic by symptom and run the diagnostic listed for that problem. You should be able to do most of it with a multimeter. It could be something as simple as a bad engine coolant temp sensor.
I had a problem with my converter clutch. The diagnostic led me to the converter clutch solenoid in the tranny. I swapped it out and all is well.
There are three solenoids. One for the clutch and two for the gear changes. The 4 gears are controlled by how many of the two solenoids are on at a time.
Good luck.
Gadget
www.GadgetOnline.com
Old Aug 26, 2003 | 06:10 AM
mtnfreak's Avatar
Is your truck warming up normally? A stuck thermostat or an electric fan that runs too much will lower the engine temp to the point that the ECU disables the overdrive. This causes you to run at higher RPM's and brings the temperature back up to the range it is supposed to be in. This allows the engine to run more efficiently and cleanly.
Old Aug 26, 2003 | 02:43 PM
MTL_4runner's Avatar
Gadget
That's pretty cool Gadget, I didn't know that!
Have yet to delve into the tranny as much as you have.
Old Aug 26, 2003 | 02:46 PM
dropcivic's Avatar
It does take a while to warm, like about after 15-20 min of driving. Where should the temp gauge sit normaly on a 4runner? But when the engine is warmed up, it idles funny, almost like a misfire of a bad gasket, but there is no mixture of oil and coolant in the system.
Old Aug 26, 2003 | 02:52 PM
Could you have a thermostat stuck wide open?
Might actually be keeping the engine too cool.
Old Aug 26, 2003 | 06:12 PM
mtnfreak's Avatar
This ain't normal. In Florida you shouldn't ever go over about 5 minutes at idle. Check your t-stat and fan controls.
Don't know about the temp gauge position on your model. Is the owner's manual any help (hey, it could happen!).
Old Aug 27, 2003 | 01:49 PM
dropcivic's Avatar
Didn't come with a manual. I thought it was taking too long to warm up and you metniod TW sensor, and it kinda fits. I had to replace the TW on my Honda when it idles funny, almost like a miss, but it was a manual. I going to order a service manual tommorrow. Fan controls? Where is the thermo and TW on a 4runner before i go searching for them?
Thanks
Blamalam
Mar 12, 2022 07:34 AM
raptor510
Aug 19, 2015 02:15 PM
129Creepin
Aug 5, 2015 10:12 PM
jimkoz26
Aug 5, 2015 03:15 PM
yourrealdad
Jul 29, 2015 11:08 AM
