tails light problems!!
Old Oct 29, 2004 | 05:34 AM
SHANEMAN's Avatar
Hi guys!
I have a problem with my tailights. When the headlights are on, the left green arrow inside the cab stays on, regardless if I have activated the left blinker or not. in others words it always stays on. If you look the front, just a solid yellow light, the back is solid yellow. Now when i turn the headlights off and turn on the left blinker, the green arrow inside the cab blinks normally, but the tails light are messed up. both running lights blink along with the left yellow. I'm so confused. any ideas?
Old Oct 29, 2004 | 05:54 AM
SHANEMAN's Avatar
i forgot to mention that i do have a wireharness for my boat trailer
Old Oct 29, 2004 | 08:34 AM
SHANEMAN's Avatar
t t t
Old Oct 29, 2004 | 09:10 AM
4Hummer's Avatar
Sounds like something is shorted or wired wrong.
Id dissconnect the wire harness for the trailer and see
Old Oct 29, 2004 | 12:12 PM
oops-sorry's Avatar
it kinda sounds like a combination of a blown turn signal bulb and wiring problem for the trailer harness. it sounds like they tried to use a standard type plug, for the type of vehicle that uses the same bulb for brake lights and turn signal. good luck--hope i helped some
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
