tacoma-4runner header swap (2.7L)
Old May 19, 2006 | 03:42 PM
Skrillah's Avatar
Does any one know if I can use a 96-98 tacoma header in a 97 4runner, the thing that makes this tricky is that its a 2.7L engine. I know its not a direct bolt-on underneath to the main exhaust but generally I thought these two models had the same 2.7 engine set up?! So why wouldn't it work.....right?
Old May 19, 2006 | 09:14 PM
Elton's Avatar
i dont see why it wont work the motors are the same so it should bolt on im sure some one will correct me if im wrong
Old May 20, 2006 | 05:07 AM
Skrillah's Avatar
Exactly what I thought...
Old May 20, 2006 | 08:25 PM
Skrillah's Avatar
Someone has to know this....!!
Old May 29, 2006 | 11:45 AM
FastOlds's Avatar
my understanding with the 2.7 headers is that the difference between the two models are how they are attached to the exhaust. The 4runners cat is part of the down pipe, where the Tacoma has a flange in front of the cat. When you replace the manifold with a long tube header on the tacoma, you would replace the pipe in between the manifold and cat. What you would need to do is replace the cat on the 4runner with a cat for a tacoma.
But other than that, from what i've read, the header location and whatnot are the same. I did a lot of reading on this when i was working on replacing the cracked manifold on my 98.
good luck
Old May 29, 2006 | 02:45 PM
Skrillah's Avatar
Yeah thats my understanding now too after doing extentsive research....what did you end up doing?
Old May 31, 2006 | 03:56 PM
FastOlds's Avatar
I went with the stock manifold. Didn't see how the header would give me that much more power without doing the rest of the exhaust.
RatOmeter
Oct 22, 2015 03:17 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
clok
Aug 1, 2015 09:42 PM
Coreyr384
Jul 10, 2015 11:13 AM
