Sway Bar End Links
#42
The stabilizer bar is NOT a weight bearing part, it is a TORSION bearing part. The reason that the links snap is due to the shearing stress of the bar twisting to keep the car on a level plane. That is why lifting the vehicle make it more likely to break the end links b/c you are messing with the factory geometry of the stabilizer bar (hence the relocation brackets) and adding more shearing stress to the bar which transfers to the links.
#43
all I know if if you put yur hand between the endlink and the swaybar you will think someone just dropped the whole vehicle on yur hand. In my mind torsion, transfer etc don't matter it's still weight.
Since weight is a big problem maybe I should say load bearing then?
#44
A another example of weight/torsion bearing would the ifs torsion bars. I think we can all agree the torsion bars are weight bearing and is the same concept of twisting force as the end links on a sway bar.
#45
weight and torsion are two different things, think of it like this, put your arm out palm up and put some books in your hand...thats weight. Now, on that same outward stretched arm, have a buddy come up and give ya an indian burn...thats torsion (in simple terms).
#47
I've broke three endlinks in the last 50k miles and awhile while back I broke an OEM one with less than 10k on it while off roading and decided when my budget allows I'll be replacing them with Wabbit's parts since I hopefully will never deal with that issue again.
OEM doesn't handle hard hits from repeated bashing on rocks and probably pothole hits do the damage also.
#50
#53
Hoewever, I believe that the twisting from the sway bar combined with the movement of the control arm is what is snapping it kinda like you would bend a straw. The endlink itself doesn't get twisted like a torsion bar.
If you have ever broken a drill bit or a torsion bar you would know what a torsion break looks like.
#54
Even if I never intend to disconnect them? I totally believe in overkill being just about enough for any situation, but is there a non-disconnecting link that would work as good? Or just go with Wabbits and forget about them?
Great! this website is gonna cost me more money!
#55
#58
Today's my birthday... free set?
The end links do not bear torsional stress unless they are over tightened. They bear (or should bear) force in a virticle plane...
Having said that, I just purchased lifetime replacements from NAPA... for the price, I should have just purchased Brian's... But this truck has no need for disconnects...
#60
I do end links as well as discos. You shoulda checked with me first.
