Supercharged 4Runner at Altitude
Old Jul 21, 2006 | 07:05 AM
mastacox's Avatar
Ok, I accidentally hijacked a thread somewhat so I'm starting a new one from where we left off:
Originally Posted by mastacox
It's a '98, in NC:
Here's what it currently looks like, Graham has done a great job of building and taking care of this rig, I am totally STOKED!!!
https://www.yotatech.com/forums/f2/some-new-pics-1-inch-body-lift-89891/
The classified listing:
https://www.yotatech.com/forums/f180/1998-supercharged-4runner-sale-boone-nc-83458/
The fact that it already has so much done to it really puts me on top. Two days after I get it I'm having a URD Fuel Upgrade Kit and 2.2" Pulley installed, then I'll be ready to ROCK! I might also get a 2.1" pulley for high altitude, for swapping back and forth (since Los Alamos is at 7500 ft) but I'll get an EGT gauge first to keep an eye on things.
My little 3.Slow struggles at altitude, maybe around 105hp I think, so I am SO ready for a big bad 3.4
Originally Posted by mt_goat
Sweet truck, good score!
Yeah I mainly got the 2.1 inch pulley because of my trips to the Rockies and the high elevation. If you read Gadget's "u-tune" write-up he said at around 5000 ft your actual boost (relative to sea level) is cut to about 3 psi with the stock pulley, even though your boost gauge will read 6-7 psi. If it's that low at 5000 ft image how little the boost would be up here: http://community.webshots.com/photo/...42310107iSWMTL
Yeah, the gauge is a "relative" one, not true "absolute," so it only measures the difference between the pressure you are at, and the boost pressure. Air pressure at sea level is 14.7 psi, so with a 9 psi pulley (read: URD 2.2") you are putting 23.7 psi into the engine. But, at 5280 ft the air pressure is about 11.8 psi and at 7500 ft it is only 10.8 psi... So at 7500 ft I will only be putting 19.8 psi in, but with the 2.1" I should be able to get back up around "Sea Level" boost ranges. But, like I said, I want an EGT gauge first since Los Alamos is at 7500 ft, but I may go down to around 5500 ft some times, and I don't want to mess with water injection, yet... I'm going to get a 2-pod to put my boost gauge in one and the EGT one in the other.
By the way, what goes into installing an EGT gauge anyway? Is it easy or a huge PITA? I'm really more curious as to what goes into installing the probe, the gauge is easy. Disconnect the exhaust at the cat, drill hole about 8" from exhaust port, and blow out chips, something like that?
And, continue...
Old Jul 21, 2006 | 07:49 AM
mt_goat's Avatar
Do you have headers or the stock manifold?
From what I understand you want to place the probe very close to an exhaust port, like within 4 or 5 inches. I am having a harder time doing that because I've got a 2001 stock manifold and in around 2000 they started using a double walled tube type manifold. This makes welding a bung and getting a good seal on the inside wall very difficult. The older ones were single wall cast iron and should be easy, some have recommended using the EGR port.
I've decided to drill my hole for the probe after the manifold as soon as my cross-over starts (my custom cross-over is single wall tubing). This will still be pretty close to 2 of the ports and maybe about a foot away from the 3rd port. I'll post a pic later, just starting this probe install right now.
Old Jul 21, 2006 | 08:02 AM
mastacox's Avatar
Well I look forward to seeing what you end up with.
Old Jul 21, 2006 | 08:43 AM
midiwall's Avatar
Correct. The EGT probe needs to be 4-5" away from the exhaust port that is farthest away from the fuel pump. This is because you want to measure the worst case, the worst case will be the leanest cylinder, and the leanest cylinder will (technically) be the one farthest from the fuel pump.
On our engines, this will be the front cylinder on the driver's side.
Getting a probe in there is tricky, there's not a lot of room to work. You also want to be sure to run a probe on a threaded bung, DO NOT USE A CLAMP-ON, it'll leak like a sieve.
Past that, the install is easy. Run the probe wires through the firewall to the gauge, run power to the gauge, mount the gauge and fire it up. 1450* is the top end for a 3.4L.
Have fun!
Old Jul 21, 2006 | 09:23 AM
tour4fun's Avatar
Where did you get that figure from?
What confuses me is how people are using EGT's to tune? I use mine as an indicator to get my damm foot off the pedal (it hangs around 1500* with my foot down) and I also wait for it to get below 800* before I turn off the car.
I don't know any better, so please edumacate me .
Old Jul 21, 2006 | 09:39 AM
midiwall's Avatar
Ahhh... lurking are we?
Mr. G:
http://www.gadgetonline.com/Gauges.h...monitor:%C2%A0
EGT Gauge
The exhaust gas temperature (EGT) gauge shows how hot the exhaust gas is.
If you see the temps going up as load increases and then suddenly see the temps drop off, be careful. That is a sign of detonation and a tremendous amount of heat is being absorbed internally and could lead to an engine failure. Look out for that. In my dyno testing max power was between 1400-1450 F. Over 1450 the power would drop off indicating a loss of power from to lean of a mixture.
I think WOT tuning with an A/FR meter is fine, it's certainly quicker, but at the $$$ I paid for the LM-1 - ouch. Having used it a few times, I'm comfortable in tuning with the EGT, ear and seat-of-the pants. Is it dead-on-ballz accurate? No, and I wouldn't recommend doing it that way if you've never tuned before.
When I bash the pedal, I can watch the EGT and listen and get dern close to setting up at 12:-12.5:1. At the temps we're talking about, the line is pretty fine between power/no-power, and the results are very black & white. Once you relate the A/FR to what you hear, feel and see on the EGT, you'll know it. It's not hard to replicate.
Old Jul 21, 2006 | 10:32 AM
tour4fun's Avatar
Sorry to hijack your thread
Maybe I should just clarify that I'm in a totally different situation. I've 6 additional injectors so I can dump as much fuel as I want to 'cool' things off. Yes, I'm also aware that running too rich robs power.
Old Jul 21, 2006 | 10:41 AM
mastacox's Avatar
LOL, and this thread was made to quit jacking another one!
It's no big deal, we are having useful conversation that I am learnig from so let's continue!
Old Jul 21, 2006 | 10:48 AM
rimpainter.com's Avatar
I installed my probe in/on the EGR block off plate on the #3 (?) cylinder port. I welded the supplied bung from the Z-series guage into the plate after I drilled a 9/16 hole. Install is very easy if you are comfortable with tapping a cast manifold or header (depending on your set up).
One thing we need to remember is that EGT's will drop (often suddenly) upon pre-detonation situations. Also, too much timing retard (which in my case might be a serious problem) can raise EGT's excessively. I am running 10 degrees of timing retard in places; I will know what this has done as soon as Autometer sends me the latest probe (the current probe has a grounding problem so it doesn't work).
I am really looking forward to seeing the before and after EGT's once I get some new injectors installed. That should be "cool" to see.
Old Jul 21, 2006 | 10:59 AM
tour4fun's Avatar
Please tell me more about this. I've got 2 of them. I thought one didn't work because of the wire, the sender and gauge seemed to work. I bought another one because you can't buy the wire by itself, it comes with the probe. Now that one is spinning around in crazy circles.
, how did you know it was a grounding problem.
Old Jul 21, 2006 | 11:22 AM
midiwall's Avatar
And I'm still waiting on my to come back from being milled.
Old Jul 21, 2006 | 11:30 AM
Apparently there is a grounding problem with the probe (the guy at Autometer told me this with confidence) once it is screwed into the manifold (or header). So, even after all the wiring is hooked up correctly, turning the ignition "ON" will result in the guage needle "bottoming out" on the low side. If you are experiencing this, call Autometer and get on the list for the updated probe. Mine should be in Phoenix by now, but I am typing this from Seattle at the moment so I am not sure if it came yet. Summit Racing has subsequently pulled all pyrometers with this issue and will not sell them until the update is complete. I freaked out and re-did my wiring a couple times thanks to this problem, only to find out it was a design flaw that only affects some vehicles.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
mengquis
Jul 13, 2015 10:39 AM
Cplmike
Jul 8, 2015 08:47 PM
