Stripped bolt in the frame rail
Old Mar 20, 2004 | 01:57 PM
ts1's Avatar
ts1
I was tightening the bolts hold my new bumper up and I stripped the one which holds in the support for the bumper closest to the rear tire.
My question is how do I fix this because the frame is boxed, I have no access to getting a larger nut inside so I could just use a larger bolt?
Old Mar 20, 2004 | 02:18 PM
RidgeRunner's Avatar
Any chance of substituting a self-tapping bolt? I used those to bolt my sliderz to the frame.
Mick
Old Mar 20, 2004 | 02:32 PM
toy283's Avatar
Or you could always Heli-Coil it. I've run into problems with that before though because the welded nut has broken loose during the re-tapping. Worth a try though.
Old Mar 20, 2004 | 02:56 PM
86toyota's Avatar
One other option,but you'll have to take the bumper back off. Can you drill through the old welded nut and drill out the other side of the frame, and use a longer bolt and locknut.
Old Mar 20, 2004 | 03:22 PM
Fahrenheit 451's Avatar
Be careful if you go this route though. You can cause the frame rails to collapse inwards if you over tighten it and don't use some sort of sleeve to support them.
Old Mar 21, 2004 | 03:27 AM
toy283's Avatar
BTDT, bad juju.
Old Mar 21, 2004 | 05:45 AM
MTL_4runner's Avatar
Good idea but I do not suggest doing this.
Either tap for a larger bolt or use a helicoil (I would use the helicoil myself).
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
yourrealdad
Jul 21, 2015 11:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
