1996 Surf with ABS but no BPV - HELP
Old Mar 21, 2004 | 12:48 AM
KZN185W's Avatar
I can't find the brake proportioning valve on my Surf. I crawled under the rear suspension but could not find the BPV.
All I saw was a hose coming from inside the body just above the left wheel. The hose goes into a Tee attached to the diff. Then from the Tee, one line goes into the left brake and the other to the right brake.
I wanted to fix my sluggish brakes (see my previous post) by attaching the bracket to the BPV. To my surprise, there's no BPV. Up front, two brake lines from the master cylinder go straight into the Aisin ABS box beside the master cylinder.
I'm now at a loss on how to improve my brake performance.
Has anyone with a 3rd gen successfully converted from rear drums to rear discs? Maybe from the LC95 series Prado?
Hope anyone can help on this matter.
Thanks again!
Old Mar 21, 2004 | 05:46 AM
MTL_4runner's Avatar
Thanks again!
Can you post some pics on www.webstots.com so we can see what you are looking at?
Like I said, I don't think that will be your answer anyway.
bryan34w
12
Sep 30, 2015 02:50 PM
JimiJams
Sep 28, 2015 06:14 PM
BimmerSage
Sep 17, 2015 11:48 PM
matt1833
Sep 16, 2015 07:11 AM
zz_denis
Sep 6, 2015 03:43 PM
