Stinking damn EFI fuse
Old Jan 29, 2005 | 12:44 PM
4Crawler's Avatar
Sounds like a short in the wires running to the fuel pump most likely, or that the pump is pulling too much current. You could check by disconnecting the connector at the ful pump, often can be done through an access hatch under the rear seat. If the fuse still bolws, then the problem is in the wiring.
Old Jan 29, 2005 | 01:10 PM
rah1420's Avatar
I'm all about that, but I can't for the life of me figure out how a 2nd generation seat bottom comes out. It looks like there's a hinge at the front of the seat, but the back of it looks very well secured and I can't find a latch or anything.
Anyone know how the friggin seats pop out?
Old Jan 29, 2005 | 01:29 PM
4Crawler's Avatar
If it is like the 1st gens, there is a sort of latch down behind the back of the cushion. As I recall, it has a loop on it that you pull up on the release the latch and lift the cushion with.
Old Jan 29, 2005 | 01:38 PM
rivercat's Avatar
yes that little loop always falls down in 'THE VOID' and can be a pita to get... but its there
smilen724
13
Nov 8, 2015 04:11 PM
mreagen
Oct 5, 2015 04:27 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
rmill05
Sep 27, 2015 01:43 PM
