Steering noises
Old Sep 27, 2004 | 11:54 AM
four.runner's Avatar
Steering noises
Hi
I have a 91 'runner, and when I do a full lock turn....like as in all the way cranked.......I get a nasty clunk/grinding sound. My friend said it was that the power steering doesn't turn that far.....but that doesn't make much sense.
Has anyone else had this problem?
Any help would be appreciated.
p.s. this is just in normal 2wd mode, and seems to have nothing to do with what kind of surface I am on.
Mark
Old Sep 27, 2004 | 01:49 PM
eric-the-red's Avatar
Originally Posted by four.runner
Hi
Mark
Sounds like the famous 2nd gen steering stop problem. If you search here you'll find a lot of people with the same problem. Basically the steering stops have plastic caps on the ends and when they wear out you get metal on metal, sounds bad but doesn't do any damage. You can replace the plastic caps but they just wear out again.
Most people just grease the ends of the stops. Look on the inside of the front wheels you'll see them, 2 on each side, one in front and one behind. Try greasing them and the noise should go away.
If you live in a rain forest like I do they require almost monthly applications of grease. On the other hand you can really freak people out in parking lots by making that noise on purpose. They look at your truck like it's about to blow up
Old Sep 27, 2004 | 06:04 PM
AhHA.......exactly the reply I was looking for. Thanks alot man, I will try that.
Mark
jashoeuh
Nov 18, 2024 08:08 AM
norcal98
Aug 10, 2015 06:20 AM
gillesdetrail
Aug 3, 2015 04:43 PM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
terminator
Jul 27, 2015 07:13 PM
