Starting problems....
Old Aug 9, 2004 | 09:08 AM
joshik's Avatar
I have a 91 3.0 yota pickup. The past few days i've been having some starting problems. I'm figuring it may be the starter...
After the truck has sit in the sun for a bit, like before i go to work, or wherever, i turn the key, there's a 1 - 1.5 sec delay before it starts to crank.. and then fires right up. It never did this before. If i leave it in the shade like under a tree at work, it cranks right away. Once, after parking in the sun for 30 mins, it wouldnt crank at all. I kept on trying and trying... and then it was time to call road side. After trying to get a hold of them, i tried one more time, and after holding it for a sec it started.
Could my starter be going bad? Or maybe my battery? not enuf juice to crank it over?
Thanks!
Old Aug 13, 2004 | 12:47 AM
nunsa's Avatar
Thanks!
1st, Check the condition of your battery, you can go to any Autozone, Shucks.., and they will do it for free! From what you're describing it sounds like your starter contacts are on thier way out!
Good Luck!
* Harry *
Old Aug 20, 2004 | 07:30 PM
mtnfreak's Avatar
I had a similar problem - only happened when the engine & air were hot. Replaced starter, battery & cables. Added a starter relay and haven't had a problem since. With the 5spd, you should already have one - if it's bad, replace it with an aftermarket - Toyota wants like $200 for theirs. If you don't have one, you can get all of the parts at Radio Shack for less than $20. Take the small wire that goes to your starter now & plug that into the 'Activation' terminal of the new relay. Run a ground, then a wire from the battery to one of the 'switching' terminals and another from the other terminal to the starter (where you removed the original wire). Roger Brown also has a write-up on his site.
Old Aug 20, 2004 | 07:45 PM
GaBowman's Avatar
Guys, having a clicking problem with my starter on a '91 P/U and ready to replace the starter. Have a 3.0 6 cyclinder motor. Do any of you guys foresee a problem changing the starter? Is everything easy to get to? Any special tools needed?
GB
Old Aug 20, 2004 | 08:09 PM
mtnfreak's Avatar
GB
I won't rip you since you're new, but the Tech Articles here on YotaTech rock!
This should be what you're looking for: Starter repair & replacement.
The links at the bottom of the page are really helpful.
Good luck.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
