Starting Problem after swap
Old May 17, 2004 | 08:07 PM
patterson's Avatar
i just swapped out my v6 out of my 90 toy 4x4, for a different but same engine, everythings wired up, but imnot getting any spark, i believe i fried the coil, what are some possible causes of this and are there any easy fixes
kinda of confusing because im not very good with electrical bull
Old May 17, 2004 | 08:33 PM
Forerunner's Avatar
Umm.. assuming it is not under distributor cap, and that you tested for the spark from the coil and got none, I would check the coil and the igniter. The easiest way to do it would be to take the coil and the igniter from a friends car and plug it into yours. Alternatively, you can get specs for the coil from the net or a repair manual and test the coil with the ohm meter. Try autozone.com for free online repair guides.
But first and foremost, I would check all the wire connections. Maybe something is loose after reassembly.
Crazychris1871
Jun 27, 2016 10:38 AM
vasinvictor
Jan 20, 2016 12:39 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
Edionne13
Jun 21, 2015 11:37 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
