180* or 195* Thermostat in 22re
Old May 17, 2004 | 04:00 PM
86toyota's Avatar
What temp thermostat is originally in a 92 22re. The auto parts store gave me a 195, but the old one was a 180. I'm replacing the Tstat, rad cap, and fan clutch because it had seems to be running hotter than usual . It was always reading about 1/8 to 1/4 on the guage(now I know why...180). What's recommended.
The gauge has been reading 1/2 way lately, and the rad and overflow are where they should be. Also no mixing of fluids.
Old May 17, 2004 | 05:11 PM
86toyota's Avatar
anyone?
Old May 17, 2004 | 08:00 PM
kyle_22r's Avatar
i believe carbed engines use the 180* thermostat and EFI trucks use a 195* one...using the carb thermostat is supposed to be a performance upgrade or something
Old May 17, 2004 | 08:08 PM
Plays_with_Toys's Avatar
I am running a 180, and must have had a 195 before, because I had run in the middle all the time and now am at 1/8-1/4. So I would say go with the 180. Its what my owners manual said also.
Old May 17, 2004 | 08:40 PM
Forerunner's Avatar
I think that is correct, it depends on the engine. I used to have a 22Rec and remember looking up the thermostat specs for it when replacing it. I would say you should also consider where the car will be driven. I would probably go with 180 degree one if I were, say, in AZ desert But going with manufacturer's spec is fine. Either a Toyota dealer, your owner's manual or a parts store should be able to tell you what temp is the OEM thermostat in your engine.
Blamalam
Mar 12, 2022 07:34 AM
JaredL
Mar 28, 2016 09:08 PM
Tennesseestorm
Sep 12, 2015 01:37 AM
Iceman4193
Aug 28, 2015 08:43 PM
