starting after head gasket change
Old Jun 10, 2004 | 11:41 AM
needayota's Avatar
hey all i finally got my engine back together and am now trying to start it.
well there is a problem.... when i try to start it, it cranks over but has loud popping noises coming from the exhaust (this is when it is trying to start becuase it will not run yet becuase i think the battery is shot beyond all hope)
any help would be greatly appreciated thanks guys.
btw. its a 1986 toyota 4-runner 5sp. with a 22-re engine.
Old Jun 10, 2004 | 12:39 PM
radrex's Avatar
Your timing is way off. Did you get the Timing Chain/Belt on properly.
midiwall's Avatar
well there is a problem.... when i try to start it, it cranks over but has loud popping noises coming from the exhaust...
Sounds like the timing may be way off.
Old Jun 10, 2004 | 01:25 PM
eric-the-red's Avatar
Timing is probably way off, or if you had the distributor out it may be 180 degrees out, ie firing on the exhaust stroke, BTDT myself.
Old Jun 10, 2004 | 10:24 PM
needayota's Avatar
ok ,
when i took the head in to get the valve job, and other stuff, the mechanic siad that he set the correct timing on the head and all i had to do was put the #1 piston at TDC which i did... so the timing SHOULD be correct.
now that you mention the distributor, i didnt really mark where it was or anything and i basically just stuck it in (probably pretty dumb now that i think about it). so how do i go about setting the correct timing and setting the dist. correctly when it wont even run?
thanks alot guys
Old Jun 10, 2004 | 11:24 PM
jimbo74's Avatar
pull plug one and set it to tdc again... take the rotor cap off and put the rotor at a 45* angle facing the front of the truck.... put the cap on..... if you have a manual (fsm) or haynes or chiltons, there is a picture of this
Old Jun 11, 2004 | 06:48 AM
ok ,
thanks alot guys
Make sure #1 is at TDC on the compression stroke, both valves should be closed. If you put your finger over the plug hole you will feel the compression. The piston could be at TDC on the exhaust stroke, then you wouldn't feel compression, and the exhaust valve will be open.
Then remove the distributor and replace it with the rotor lined up with #1 terminal. Rotors usually rotate when the distributor is inserted so this may take a few tries.
Old Jun 11, 2004 | 08:41 AM
needayota's Avatar
ok sounds good.
where is the rotor? under the dist. cap?
thanks alot man
Old Jun 11, 2004 | 08:43 AM
ok sounds good.
thanks alot man
Yes, take the dist cap off
Old Jun 11, 2004 | 11:11 AM
needayota's Avatar
ok made suggested changes ( i believe correctly). and put new gas in it ans a new battery.
so here is what goes down NOW!:
it doesnt back fire anymore so that means that the timing is more correct than it was before and it does START but will die immediatly after no matter how much gas i give it.
any suggestions?
Old Jun 11, 2004 | 11:19 AM
Luke Groundrunner's Avatar
i had the same problem in my volvo once, it turned that the O2 sensor went bad, see if thats your problem.
Old Jun 11, 2004 | 11:24 AM
needayota's Avatar
put a new one in so i dont think it would. and also when those go bad the car starts and runs fine but the check engine light would be on.
any thing else? (im desperate)
Old Jun 11, 2004 | 11:35 AM
Fahrenheit 451's Avatar
Is all the air intake plumbing put together? If the intake isn't completely installed with no leaks the AFM will either not work at all or will send data that is incorrect and the ECU will have no clue what to do and the engine will not run.
Check and make sure the AFM and TPS and all that sort of stuff are plugged in as well.
I'm just pulling the trigger and hoping to hit something
Old Jun 11, 2004 | 12:30 PM
needayota's Avatar
both harnesses (tps and afm) are connected. and fine.
i think some of the vac hoses are connected wrong or something.
is there a hose diagram for the 22-re somewhere?
im talking about a complete one that has all vaccuum lines and every hose on the engine.
Old Jun 11, 2004 | 02:17 PM
needayota's Avatar
bump.
zd92655
Mar 6, 2022 12:58 PM
voiddweller
19
May 2, 2016 09:10 PM
hexrain
Jun 27, 2015 06:17 AM
gog1968
Jun 22, 2015 05:55 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
