!!Speedy's Supercharger Thread!!
Old Sep 8, 2007 | 10:29 AM
  #621
mastacox's Avatar
Originally Posted by Speedy
Went by the transmission shop and had their master tech drive Project SportRunner ... He told me the truck DID NOT need any VB work done. He said the tach dropped quickly to the next gear and the shifts were quite firm. He said I need not be concerned about transmission damage. I
... He told me it's "on or off" and that 90% of the ones he's done, even when they're a kit with specific instructions, the customers were not happy after the work was done.
...Bottom line, I'm leaving mine as is. If it ends up having an issue I'll get it fixed and regroup.
The only two people I've seen that have had a failure are Midiwall and Gadget. I believe both of which drive their 4Runners much harder than I do. If you're the type that likes to WOT it from red light to red light, or go spinning the tires up sand dunes, then a VB upgrade is probably necessary. For me, I doubt I'll have any issues. Time will tell.
Hmm, this is not what I was hoping to hear...
Bottom line is I think I'm going to need a VB upgrade as my 4Runner's going to be a Desert Bomber, with a lot of WOT 1-2 shifts. Question is, will I need it right away...
My shifts are quite firm right now (especially when I'm in 4-lo), but I have been purposely avoiding wide open 1-2 shifts... perhaps that will be good enough I did end up tightening up my kickdown cable some time ago, which went a long way to firming the 2-3 shift and shortening the 1-2 shift.
I'll just add in a tranny temp gauge, and keep an eagle eye on my temps for now. Damn, I was hoping we'd be able to get another shop that could do VB's, and start a price war with the east coast guys...
Old Sep 8, 2007 | 10:41 AM
  #622
Speedy's Avatar
I can ask the guy if he'd do one if you mailed it in if you'd like.
I'd definitely recommend a tranny cooler. Mine's running in the 160s cruising and the highest I've been able to make it get is 187 so far. Prior to the cooler I saw 220 frequently.
Old Sep 8, 2007 | 10:43 AM
  #623
blink's Avatar
Well, just ordered the Magnaflow 24" satin SS muffler with Center inlet/offset outlet P/N 12286 that has 2.5" inlet and outlet size from www.hottexhaust.com along with this tip:
I'm gonna have it run straight out the back to the right of the hitch.
I picked up a flange off a stock exhaust system from a local salvage yard. They raped me on the price at $35 but that's the only place I could find one after searching all day. I'll basically do a custom cat back exhaust using this salvage yard flange to make it "bolt on" so that I can keep the stock system completely in tact should I need it in the future. The flange I picked up is the one that connects the stock tail pipe and muffler to the second cat.
For those looking for exhaust, www.hottexhaust.com is running a sale. I got the muffler and tip shipped for $128.
Hey Speedy,
Wish I was able to post before you purchased anything.
When I had my v8 stock, the same muffler was installed. I was pretty disappointed as I ended up losing torque down low in exchange for hp up top. I figured that most of my day to day driving was going to be in the 0-65 range, where I would benefit more from torque then the hp increase.
This muffler with its straight through design flows too much on a v8, and even now that I am s/ced its still hurting me down low. Hopefully since you have a roots type s/c youll not be affected as much.
Old Sep 8, 2007 | 10:45 AM
  #624
midiwall's Avatar
Probably, but it's a shortsighted approach to look for people that have had failures. What you're not including are the people that had the VB work done before a failure and thus avoided one.
fwiw, "failure" comes gradually, usually showing first as a bit more time in that 1st->2nd shift.
You've spent a good amount of time since putting the SC on talking about how much grunt the motor has, and your WOT runs, and being able to break the tires loose... If you're gonna keep doing that, even causally, then you can expect gradual failure.
But if you're going to stop doing all that stuff, then ... why'd you build up the engine in the first place?
Old Sep 8, 2007 | 10:48 AM
  #625
blink's Avatar
Masta,
I would recommend getting the valve body done soon. In my 01 taco I was driving around with dual hayden coolers rated at 24,000 LBS pounds each, and kick down cable extra tight and still ended up with a messed up transmission.
Old Sep 8, 2007 | 10:52 AM
  #626
Speedy's Avatar
My goal was better drivability with the ability to open it up once in a while. I've more than accomplished both goals. Not to mention I'm a project junkie and have to always be working on something haha.
If I start to feel any issues, I'll re-visit the VB mods. The majority of my driving will just be day to day stuff and I'd rather not have banging shifts all the time for those few times I give it some go pedal. IF I have a tranny problem down the road I'll just deal with it.
I'd also wager that if you drove a stock 4Runner and did a lot of tire spinning (or tried to), and WOT red light to red light, it would also have a tranny issue over time. Obviously a SC'd motor will speed up that process, however.
Where's this cable that can be tightened to firm it up some?
Old Sep 8, 2007 | 10:53 AM
  #627
Speedy's Avatar
Originally Posted by blink
Hey Speedy,
That's odd. Nearly everyone that's SC'd says this muffler is the way to go, as well as adding headers to boot. I'll see how she does. We can always switch out muffler if need be. I'm also gonna do 2.5" pipe as well.
Old Sep 8, 2007 | 02:18 PM
  #628
mastacox's Avatar
I might have to take you up on that, $300 for a VB job is far less painless than $800-$1000. I might have to talk to this guy directly, got a phone number you could PM me?
The job this buy does includes drilling some holes larger, rerouting some lines, and replacing some springs? Would he be willing to sell a "do-it-yourself" kit for a hundred bucks?
Have had a Hayden 678 on the 4Runner since I bought it, was installed by the previous owner. Planning to add a ~1" diameter gauge down in the lower left area of the dash.
Well I don't feel like I am in imminent need of a VB since I drive "relatively" conservatively on the road (especially where the 1-2 shift is concerned), but I'm going to need one before I go to the dunes, and especially after I get the long travel suspension.
Well, there's another documented transmission failure for ya Speedy... as a matter of fact I think I know a guy in Tucson that roasted his transmission as well, but he had 38" swampers in addition to the supercharger (no fuel mods). Hard to say if his failure was due to driving like an idiot or what, but food for thought that transmission failure for these trucks is a real problem rather than a rare one.
Old Sep 8, 2007 | 03:56 PM
  #629
Speedy's Avatar
PM Sent.
I doubt it. There's no "kit" for an A340. The guy checked.
So that makes three out of how many? Two of which we KNOW are driven hard. I'm not trying to talk anyone out of doing this. I'm just gonna hold off personally and see how it goes. I'm not against spending the $300 honestly, for me it's more of not wanting rough shifting for every day driving.
Blink, what type of driving style do you have? How many miles and what type of transmission problem did you have?
Old Sep 9, 2007 | 05:07 PM
  #630
Speedy's Avatar
For what it's worth I've e-mailed IPT with a few questions, one of which being why they charge $575 for something the local shop does for $250 - $300 including removing the VB and re-installing. I'll let you guys know what I find out, if anything.
Old Sep 10, 2007 | 01:15 PM
  #631
midiwall's Avatar
There's a thread around here addressing some of that, but in the end, their line will be that what they do is proprietary info with the specifics derived after a lot of trial and error. Which is true.
I'm sure you'll disregard this, but just so it gets said...
Having knowledge of this transmission as it works in a Mail Jeep (100hp? 2000 lbs?) is a LOT different than how it works in a hopped-up 4Runner (330hp? 4400 lbs).
Be careful with your $300 guy... While I think we all agree that IPT is expensive, none of us have ever gotten back a trashed VB. A new VB ain't cheap.
Old Sep 11, 2007 | 12:29 PM
  #632
Speedy's Avatar
I never disregard anything if it half way makes sense, and although we have differed on opinion on some things I still respect your input.
I gave IPT a call and talked to Anthony who said he was the manager. He answered some of my questions, but was kind of vague, although I believe he was being as helpful as he could.
He basically said he couldn't believe another shop was doing this work for $300 and that these were custom modified valve bodies they were doing. However that is exactly what this local shop IS doing, although I can't say if they're as good as IPT or not since no one's had a 4Runner done there. :shrug: I asked him about the VB preventing tranny damage and although he said it "could" help, it was more performance oriented rather than to prevent failure. I also asked about there being levels of modification to prevent harsh shifting. He said that there "might" be some things they could do, but that shifting shouldn't be harsh, just more firm than stock.
So, that's it in a nutshell. He said if I had more technical questions I could call back and talk to John who's one of the techs. For now I'm just gonna sit tight. I've talked to a couple other people with SC'd 4Runner through e-mail and they said their 4Runners were VERY obvious when the shifts weren't firm, taking 5 seconds or more for the 1st - 2nd shift. Mine's nowhere near that, more like 1 second for me if that. If mine starts to slip at all I'll re-visit at that time, or maybe later on down the road when I need another project to fool with.
Old Sep 11, 2007 | 03:33 PM
  #633
QSVeilside's Avatar
I held off on the VB mod my truck is supercharged with the 2.1" pulley. The first to second shift always was and always will be lengthy. Takes around 8 mph on the speedometer to complete when mashing the pedal. Tightened the kickdown cable recently, which made some difference.
I'll get the VB mod eventually. If the tranny goes in the meantime, I will convert this truck to manual.
Old Sep 11, 2007 | 03:54 PM
  #634
Speedy's Avatar
Originally Posted by QSVeilside
I held off on the VB mod my truck is supercharged with the 2.1" pulley. The first to second shift always was and always will be lengthy. Takes around 8 miles per hour on the speedometer to complete when mashing the pedal. Tightened the kickdown cable recently, which made some difference.
That's kinda what I was thinking. What's involved in converting to manual? Is it just a swap in or is there a bunch of computer stuff to deal with?
Old Sep 11, 2007 | 04:05 PM
  #635
jimbob's Avatar
Just so you know speedy --- the 01-02s can't be swapped to a manual because there is no provision for the pilot bearing in the crank --- so don't make that a long term plan!
Old Sep 11, 2007 | 04:07 PM
  #636
Speedy's Avatar
OK cool. Thanks for the heads up on that. I guess if the tranny goes, she'll get rebuilt with some upgrades!
Old Sep 12, 2007 | 10:48 AM
  #637
Speedy's Avatar
I've continued to read up on the A340LE tranny that's in my 4Runner. The "E" denotes electronic and I don't believe it has a Throttle Valve cable, but is computer controlled. In some initial research I found this thread, of particular interest is the PDF in the first post.
http://www.performanceforums.com/for...03584#poststop
It seems this would be "stage 1" of what IPT does to the trans. Stage 2 would be drilling out VB holes. Stage one is simply shimming up a couple of springs.
Edit to add more from a Certified ASE Toyota Master Tech:
http://www.supraforums.com/forum/sho...d.php?t=267655
Old Sep 13, 2007 | 04:08 PM
  #638
Speedy's Avatar
Got the custom cat back done today. Luckily I made it a bolt on because I dont' like it.
Luckily it only cost me $87 do get it all put on.
I'm going to stick with the stock exhaust.
If someone wants a Magnaflow 12286 I'll sell it cheap. If feels like it lets the SC breathe easier, but I'm just too old for the sound I guess.
Old Sep 13, 2007 | 05:09 PM
  #639
mt_goat's Avatar
What, are you saying it was too loud? Maybe you want a stock Toyota muffler, hehe.
I got one:
https://www.yotatech.com/forums/f107...1-taco-117607/
Old Sep 13, 2007 | 05:31 PM
  #640
Speedy's Avatar
I got one:
I kept all the stock stuff. As a matter of fact the cat back I had made was bolt on as I got a flange out of a junk yard. I'll just bolt the stock stuff back on the truck.
Yep, I guess it's just too loud for me.
