speed sensor wire?
Old Aug 11, 2004 | 05:14 PM
halcyon0's Avatar
speed sensor wire?
I am trying to install a aftermarket radio and need to hook it up to the speed sensor wire. I have no idea where it is? Can anyone help? I have a 2nd Gen 1994 4runner.
Thanks!!!
Old Aug 11, 2004 | 10:23 PM
superjoe83's Avatar
it still may be cable on the 2nd gens, but not 100% sure
Old Aug 12, 2004 | 04:06 PM
UKMyers's Avatar
Why on earth would you have to hook up a stereo to the speed sensor wire? Anyways the sensor is right on top of the rear diff. The wire runs up the right side of the axle mounts to the frame and the plugs in right on top of the frame up by the gas filler neck. The whole thing is about 3 feet long.
Old Aug 12, 2004 | 04:16 PM
Robinhood150's Avatar
The sensor on the diff is the rear ABS sensor. The VSS is in the back of the transfer case. I know this because I replaced it when my speedo went out.
halycon, try a search for VSS and my name and you'll find some pictures.
Old Aug 12, 2004 | 05:09 PM
halcyon0's Avatar
It is actually a stereo with built-in GPS. Does the speed sensor wire go into the cabin anywhere? Maybe behind the speedo?
Old Aug 12, 2004 | 07:43 PM
UKMyers's Avatar
Thanks for the correction.... I read that a little fast I guess
Old Aug 12, 2004 | 09:07 PM
Ah, when I was diagnosing my VSS problem the manual and codes pointed to the rear abs sensor. Maybe that's where the confusion came from.
Halycon, it's got to go into the cab somewhere. I don't know where though. Try searching, I know some people have replaced their speedo.
sandyota
Feb 4, 2021 11:16 AM
BeMiceElf
Oct 10, 2015 09:40 PM
88yodabasket
Jul 13, 2015 01:32 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
