Specs on a 22R?
Wow....thats about as much power my 1992 2wd Isuzu 2.3 sohc carbed 4 banger made too!
Are there any mod's thatll give this puppy some power?
Kyle....your 79 looks to be taken care of pretty well! looks to be in better shape then my 81!
ahh yes, everything looks fine on the outside, but take a look underneath or under the hood
pretty much needs a complete overhaul.
'81s had the worst gearing in any toyota 4x4 from the factory, 3.90 in the axles. a cheap power upgrade from stock would be to get 2 8" third members with 4.10s and swap them into the axles. you have to pull the shafts out, though. 4.10 is the most common gear ratio through the years of toyota trucks, and can be found for as little as $40 each if you look, as a lot of people are regearing deeper to compensate for larger tires
engine-wise, there's some stuff you can do. a weber 32/36 or 38 carb is a good match for the 22R. you can also add a header and cam, but you need to pull all the head bolts to swap out the camshaft
pretty much needs a complete overhaul.'81s had the worst gearing in any toyota 4x4 from the factory, 3.90 in the axles. a cheap power upgrade from stock would be to get 2 8" third members with 4.10s and swap them into the axles. you have to pull the shafts out, though. 4.10 is the most common gear ratio through the years of toyota trucks, and can be found for as little as $40 each if you look, as a lot of people are regearing deeper to compensate for larger tires
buckz6319
Aug 5, 2017 03:50 AM
Toys4parts
Sep 26, 2015 01:56 PM
