Speaker Replacement
Speaker Replacement
It took a while but I finally got the stock rear speakers (under the pop out windows on the extcab) out of my truck. I'm going to fab up mounting plate to put some bigger and better speakers in there place.
The surprise was what looks to be a powered corossover or small amp (obviously a stock configuration) mounted in the plastic speaker housing (which is huuuge compared to the tiny speaker mounted in it). It was not being used. boxes still have the stock 15watt speakers in them and the stock head unit was just the plain jane stock job.
The question is - since I have 5 wires running into the speaker box and to this amp(?) then 2 different wires coming off the amp to the speaker - how does figure out which of the 5 wires are the direct speaker leads (ie +/- output from the head unit???
I can supply pics if that helps...
My guess is you have a positive, negative, remote turn on (only on when the radio is), and rear signal (+ & -). Then to the speakers you only need the signal + & - (left and right).
Make sense?
I don't have that setup (built my own system), but that's what wires are running to my amp.
Todd
Make sense?
Todd
Makes perfect sense - that's what I was assuming. I'm just trying to tap into the existing wires to hook up the speakers but it looks like i'm going to need to run fresh wires. Dang, and I just put the dash back together.
sandyota
Feb 4, 2021 11:16 AM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
