Spark Plugs
Old May 6, 2006 | 03:43 AM
SHICKS's Avatar
Spark Plugs
Hi Everyone.
It's a beutiful Saturday morning here in New Hampshire. I plan to replace my plugs on my 2002 4Runner with 3.4v6. It came with two different brands of plugs.
I went to the auto parts store and found 6 NGK BKR5EKB-11 for $6 each.
My question is can I use this brand and type on all 6 cylinders, or should I go to another store to find the DENSO brand for the other 3 cylinders?
Thanks in advance,
Steve
Old May 6, 2006 | 06:08 AM
hupptoy's Avatar
You can use the NGK's in all 6 cylinders.
Old May 6, 2006 | 07:10 AM
SHICKS's Avatar
All done, it took one hour start to finish.
She runs much better. I had 45k on the originals. It was not starting as fast and kind of felt sluggish, but I am sure that is all in my head.
Thanks
Steve
Old May 6, 2006 | 07:29 AM
fireteacher's Avatar
did you check the gaps on them?
Old May 6, 2006 | 07:46 AM
jrallan26's Avatar
I need to do the same. Was it tough?
Old May 6, 2006 | 01:32 PM
SHICKS's Avatar
Nope, not at all. A few tips. Tape your socket to the extension, I learned that really fast. The passenger side is easier than the drivers, even though you have to remove the intake tube. Other than that, it took me about an hour including running in the house a few times.
Steve
Old May 6, 2006 | 07:27 PM
jtmaxx7's Avatar
I changed mine at 60k. It runs a lot smoother now. Oh yeah all NGK's and gapped prior to installing. Supposed to be .043, however all but one was at about .040. Someone said just install. I don't think 3 hundredths of an in makes a diff.
Old May 6, 2006 | 07:34 PM
Tanto's Avatar
They should all be gapped the same.
Old May 6, 2006 | 07:46 PM
rimpainter.com's Avatar
^ yep, and you need to use a wire-feeler type guage to do it right. Mine were way off when I got them.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
