Some ?'s about maintenance.
Hey all,
I have a 2002 4-Runner 4x4 Limited Edition. I have 52k on the clock and she's running great. Just would like to get some feedback on some maintenance that will need to be done eventually.
1. R+R front rotors/pads.....is doing the job different on a 4x4?
2. 60k or 90k for replacing the timing belt? Should I replace the water pump as well?
3. Best spark-plugs to use?
4. Best coolant to use and how often should I replace the hoses? ( I live in AZ.)
5. Best online sites to buy Toyota parts?
Thanks in advance for all your help and advice!
trdparts4u is the best place to get parts on line, Strap22 (phil) is on here, and works there, he'll help you out...
other than that, someone with a newer truck is gonna have to help you out.
Originally Posted by READYFORTHEGRIDLOCK
Hey all,
1.) Easy to do on this one.
2.) I still change at 60k and a water pump is cheap insurance and easy change when you are this far into it.
3.) Nippon Denso....Factory Plugs
4.) Toyota Red Only
5.)you can place orders and make inquires to:info@trdparts4u.com
Originally Posted by strap22
Thanks AxleIke for the bump........
3.) Nippon Denso....Factory OEM Plugs
4.) Toyota Red Only
4.) Toyota Red Only
......non interference engine so no worries about damage on t-belt.
Originally Posted by MTL_4runner
Ditto except I go 90k on the t-belt (most new belts will go 100k no problem) and water pump is debateable as well.
Truckwithoutaname
Oct 3, 2015 03:41 PM
mordell
Sep 12, 2015 10:13 AM
