Softer shocks?
Old Mar 22, 2005 | 09:22 AM
-MaTTi-'s Avatar
Softer shocks?
I have Monroe Gas Magnums under my 2nd Gen 4Runner now. I think they are a little bit too stiff (heavy duty?).
Tell me your opinions, which are the best shocks which offer smooth and soft ride?
Old Mar 22, 2005 | 09:42 AM
4RUNR's Avatar
Guest
On the road smoothness comes not from the shock, but from the tire type and pressure.
Old Mar 22, 2005 | 10:14 AM
-MaTTi-'s Avatar
I don´t fully agree. They have an influence, I know. Tire pressure make a big difference. But you are on tires/springs/shocks(/seat) while driving. Everything have an influence on driving comfort.
Old Mar 22, 2005 | 11:34 AM
Steveh29's Avatar
I had bilsteins on my truck and they did make it ride harsher than the Rancho 9000 adjustable shocks I replaced them with. I'm much happier with the Ranchos. I also had the Sway Away front torsion bars and they REALLY made my 4Runner ride rough. I had to take them off and go back to cranked stock bars.
Old Mar 22, 2005 | 11:58 AM
JM's Avatar
JM
I had the same problem. I have to drive across a 24 mile Causeway bridge everyday to work so I bought the cheapest (red ryder ) shocks from Autozone and it made a big diffrence. Best of all they have a lifetime warranty . I know they may not be the best for offroad but you may want to go this route if you want a nice on road ride.
When is the last time you seen a Cadi with heavy duty shocks?
Old Mar 22, 2005 | 02:04 PM
4RUNR's Avatar
Guest
Can't say I ever driven in Finland, but I'd imagine due to the climate it's similar to north-east USA with a mosaic of patch-type asphalt fixes. Running over 1-2cm bumps or depressions should not invoke the shocks/coils, by design.
Try airing down to 15 psi (1atm) rear and 25psi (1.7atm) front, just as a test. Forget all you heard about 'right' tire pressure. Then come back and tell me it doesn't ride smooth enough.
Old Mar 22, 2005 | 03:14 PM
Paul H.'s Avatar
Tire pressure and tire type ( bridgestone Dueler AT's give a better ride than BFG AT's) makes a big difference as does shocks. I have Skyjacker Nitros and they are smoother than Rancho 5000's.
Old Mar 22, 2005 | 03:23 PM
terryjmatthew's Avatar
https://www.yotatech.com/forums/f2/can-aftermarket-shocks-improve-ride-comfort-48524/
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
