so my transmission died...
Old Feb 6, 2007 | 05:58 AM
  #61
MTL_4runner's Avatar
Lee, thanks for posting those pics of what happened!!!
......just sucks that it was the planetary (mucho $$$$) that went.
That aluminum casing and steel parts are worth a few bucks to a scrap metal dealer so cash that stuff in!
Old Feb 6, 2007 | 06:19 AM
  #62
lee's Avatar
lee
too late
thats ok, i am gonna try to sell the oil pan and the front and rear of the casing.. if i cant ill turn the front and rear in to a metal dealer as you said...
oh well. it happened and at last i got to crack it open and learn about it.. its really fascinating. i cannot believe what goes into an auto tranny.. i mean, the engineers are ˟˟˟˟˟˟ geniuses!
Old Feb 6, 2007 | 06:21 AM
  #63
mastacox's Avatar
Originally Posted by lee
too late
So lee, what kind of shape is your valve body in?
Old Feb 6, 2007 | 06:27 AM
  #64
lee's Avatar
lee
i wouldnt feel comfortable selling anything besides what i said above... everything was covered in metal pieces, not to mention once i realized there was no saving the tranny, we were less careful about taking things apart.
Old Feb 6, 2007 | 06:34 AM
  #65
mastacox's Avatar
lol oh well, it was worth a shot
Old Feb 7, 2007 | 04:49 AM
  #66
BOSTON4RUNNER's Avatar
I wonder if a sythetic fluid change would help act as cheap insurance - it is a fact that synthetics run at cooler temperatures and am sure that heavy off roading really heats it up.
I run synthetic in my 5 speed and it definitely made it shift alot better - also have it in my rear axle.
I am not sure what the Toyotas have for a factory transmission cooler, probably only runs through the radiator - jumping up to a serious and large capacity one, mounted behind the grill may also help ensure transmission longevity
Old Feb 7, 2007 | 04:51 AM
  #67
No matter what the application - racing, off roading etc - stock parts will only take you so far, however doing minor upgrades such as what I mentioned for the tranny may help out alot...
Old Feb 7, 2007 | 04:53 AM
  #68
I would maybe even do this, with a fan. Drive on the street with the cooler in place, then during heavy of road crawls etc have a manual switch set up to turn on the fan.
Old Feb 7, 2007 | 05:12 AM
  #69
lee's Avatar
lee
yeah ive already mentioned a few times that ill be adding a transmission cooler.
i need to pay this down a bit first.
Old Feb 7, 2007 | 05:27 AM
  #70
I hear you - the cost of replacing a major item can really snap your balls off
when you do go to do it, I would lean towards the overkill - one with a fan etc, that way do it once
Old Feb 7, 2007 | 05:46 AM
  #71
Reldnew's Avatar
You say it has "slipped since 44,000mi." If that slipping condition was caused by the thrust washers failing and it still took till 113,000mi before complete failure, you made out OK. That means the planetary gear set took 67,000mi of abuse before grinding themselves to bits.
Old Feb 7, 2007 | 05:51 AM
  #72
lee's Avatar
lee
yup, basically
Old Feb 7, 2007 | 06:44 AM
  #73
mt_goat's Avatar
Good Lord, wouldn't that make a lot of noise? I've heard guys say their tranny sounds like a can of marbles before.
Old Feb 7, 2007 | 06:48 AM
  #74
mt_goat's Avatar
2- fluid was changed last sept.
Any sign of metal fragments at that time?
Old Feb 7, 2007 | 07:46 AM
  #75
lee's Avatar
lee
i took it to firestone, and never asked. so i would assume they did it in such a hurry that they didnt even look.
Old Feb 7, 2007 | 08:15 AM
  #76
Lee, did the place that installed your new tranny flush the internal radiator tranny cooler by any chance?
If not it might be worth just pulling and cleaning the filter after 5k or so.
Old Feb 7, 2007 | 08:27 AM
  #77
lee's Avatar
lee
good question, ill ask.
thanks for the tip
Old Feb 7, 2007 | 05:28 PM
  #78
RunnerUp's Avatar
wow lee, that sucks! i had to replace the tranny in my 99 at 65k right before i totalled it, this one seems fine right now, though i do jolt when i accelerate from a stop sign sometimes... im just hoping that its my rear diff instead of the tranny! buy a lotto ticket, maybe you'll get lucky
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
