Snow Chains on Frt.
Old Jan 1, 2003 | 08:38 AM
needamog's Avatar
Snow Chains on Frt.
does anyone have good or bad experience using chains on the frt. end of a Tacoma or 3rd gen. 4Runner? I have two sets that I could use to chain up all 4 wheels, but it looks like the upper balljoint is too close to the tire. I have stock alloys and stock tire size.
Old Jan 1, 2003 | 08:58 AM
PhxTRDRunner's Avatar
I put a rather large set on the front of my 3rd gen. and they did rub a little on the front fender flare on the inner most portion. Nothing noticeable, but still they rubbed. Cables probably would not rub.
Old Jan 1, 2003 | 12:28 PM
upndair's Avatar
You would only need chains on the front under the most severe conditions. I think I'd choose to air down first. If you were still able to move, don't waste your time with front chains. If you're stuck, drop the air down to 5-8 lbs. You can still drive 20-30 mph with this much air. You wouldn't go any faster with chains either.
You could try cables but they only really do any good with a hard packed bottom. They don't do much is soft snow. Airing down will provide you as much or more traction as cables will.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
bradahman
Oct 1, 2015 09:24 AM
Project90
Sep 24, 2015 11:40 PM
