which shocks are the smoothest!! HELP
Ok i am new to the world of suspension, i know quite a bit about motors but suspension is foreign to me.
I have a 97 tacoma xtracab 2wd w/ a 3" body lift. Rancho5000 on front, and stock shocks on back.
Now, This truck will mostly be a street truck unless im taking my dirtbike out where i might have to go on a dirt road, but probably no real offroading will be done in this truck.
SO, which shocks should i buy to achieve the smoothest possible ride n the road, smooth as in not feeling little bumps and minimizing the pot holes on the road. The ranchos are waaaayyyy to stiff for me and i dont like the ride, because its very rough on bumpy roads.
Ive heard OEM would be the softest riding but what is your opinions????????
There are so many opinions on shocks. Many here are running Billstien HD's, but I've heard they're quite harsh riding. Other options include KYB, OME, Rancho, Monroe, etc. If you're just after a smooth ride, Monroe SensaTracs are a pretty good bet...if you won't be offroading much. Do a search on shocks for more info.
From: Far western Kentucky (transplanted from central PA)
If you want smoothness over good handling, then I would have to agree that the OEM shock is probably the way to go. They'll give you that original, "Soccer Mom" ride. But be aware that, IMO, 4Runners typically do NOT ride as smooth as other SUV's no matter what shocks you put on them. I have the Bilsteins and they are harsh, but I prefer a nimble, tight-in-the-corners ride.
well i have the tacoma not the 4runner, and if i was after a smooth street ride would you recommend OEM, or the monroe sensatracs??????????
i have done a ton of searching on many boards and so far ive heard that sensatracs would be the best choice for a smooth aftermarket shock, but i was wondering how they would compare to the oem shocks, Like which ones are smoother?
Definately stay away from the bils!
I'd say it would be a pretty close tie between the Sensatracs and the OEM Tokicos.
(hunch being the Monroes are slightly softer, but I can't say that with any certainty).
Cost,reliabilty and stock ride you should just go with OEM. I did the shocks and coils on my Runner and kept it around $350+shipping and I'm figuring a Tacoma setup should be similar in price.
If all you're looking for is a soft plush ride, go with the Monroe SensaTracs over the stock Tokico's. The Monroes will handle as well as stock, but are valved a little softer from what I've heard.
You can check the stealership for a part number. Then, if you want to save some dough and can do the work yourself, visit www.toyotapartssales.com for the cheapest prices on genuine OEM parts. I will forewarn you that replacing the rear shocks on a 3rd gen is not an easy process. The top nut is all but impossible to reach. There are some good write ups here in the forums if you search that will give a good step by step process.
I had the Monroe SensaTracs for about a month. HATED THEM. They were sloppy, scarry if you hit a bump going around a corner. I changes over to Bilsteins, Love them. Firm but not harsh. Yellow body w/ Blue Boot. ( https://www.yotatech.com/forums/f79/gerdos-profile-85724/ for part numbers)
i took a look under my truck after you said that and it looks like is wide open, are you talking about the 4runner or tacoma?
Originally Posted by Gerdo
I had the Monroe SensaTracs for about a month. HATED THEM. They were sloppy, scarry if you hit a bump going around a corner. I changes over to Bilsteins, Love them. Firm but not harsh. Yellow body w/ Blue Boot. ( https://www.yotatech.com/forums/showthread.php?t=85724 for part numbers)
how were the sesatracs "scary" when you hit a bump?? and how did they differ from stock oem shocks???
Originally Posted by Paul H.
OME comfort shocks are probably the best out there from what I hear.
Also depends on budget since the OMEs are a bit towards the expensive side.
