Shocks
Old Nov 30, 2003 | 04:03 AM
22Ryota's Avatar
Shocks
Wow... I am just burning up the forum lately. Thanks to everyone that helped the the pcv valve issue. I have a new question. I am not planning on lifting my truck but one of my shocks seems to be messing up or something. My truck has a slight lean to the drivers side front. This should be corrected if i replace both shocks right? it is noticeable. When i walk towards it in a parking lot i can see the lean and how it is not even. It isn't even when i am parked on level ground or unlevel groun New shocks to correct this? or what?
Old Nov 30, 2003 | 05:03 AM
CTB's Avatar
CTB
I'm guessing it is probably a spring sagging on that side, not a shock issue.
Old Nov 30, 2003 | 05:17 AM
MTL_4runner's Avatar
Yep, definately not a shock problem....I agree on a sagging spring problem instead.
Old Nov 30, 2003 | 07:16 AM
GV27's Avatar
Ditto. Shock won't have an effect on ride height. It's the springs that hold the thing up off the ground!
Old Nov 30, 2003 | 07:20 AM
Fink's Avatar
Could that be caused by a rear spring issue? If so then I would guess he doesn't have the Downey HD Coils and his rear end is still sagging too...might as well fix it all at the same time eh?
Fink
Old Nov 30, 2003 | 07:30 AM
CTB's Avatar
CTB
Fink
Just to clarify, I believe he drives an older pickup, so he would have leaf springs in the rear, not coils.
Old Nov 30, 2003 | 08:30 AM
outdoorfever's Avatar
but he said front not rear...and he only has shocks in the front correct?
Old Nov 30, 2003 | 08:45 AM
CTB's Avatar
CTB
Good call, I missed the "front" part.
Old Nov 30, 2003 | 09:08 AM
YotaChuck's Avatar
what year is the truck?
Old Nov 30, 2003 | 12:13 PM
22Ryota's Avatar
87 pickup
Old Nov 30, 2003 | 01:50 PM
22Ryota's Avatar
Ahhh ok.. a spring.. If i was taking it to a mechanic or buying one to have someone put on.. What would i call it? The front coil? Front driver side spring?
Old Nov 30, 2003 | 03:41 PM
Cebby's Avatar
IIRC, the 87 has torsion bars up front (1 left, 1 right). Might be out of adjustment or one of the adjuster bolts has fallen (or rusted) out.
FWIW, he would have shocks at all 4 corners, not just up front.
As mentioned by others, shocks have no effect on ride height (unless they are "air" shocks that can be pumped up).
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
