she won't run
Old May 7, 2003 | 04:51 PM
my95toy's Avatar
she won't run
after work today i wanted to clean my second gen runners air box so i took it apart an decided to put in a new KnN filter. I put all the stuff back in place and now the damn thing won't start. The engine will turn over fine but it just wont't run. it sounds as there isn't any fuel getting into the engine. Can anyone tell me where the fuel filter and pump are located. any other suggestions welcome
thanks
Old May 7, 2003 | 05:13 PM
It sounds like you may have forgotten to reconnect your mass air sensor. Do a good once over and make sure everything is plugged in/hooked up. It is located right after the air filter. Odds are highly unlikely that your fuel pump or fuel filter or any part of the fuel system is at fault if it was running good before you took the airbox off. good luck
Old May 7, 2003 | 07:55 PM
Sludge's Avatar
I would have to agree with heliax It seems like the MAF is not conneded properly. Check the connection ,wires or a possible bent pin
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
Tykiller1994
Aug 10, 2015 07:49 PM
hangtown88toy
Jul 10, 2015 02:33 PM
raiderhawks00
Jul 8, 2015 06:23 PM
