Shaking & vibration ??? Help!
Old Dec 3, 2003 | 04:13 AM
Originally posted by keisur
even if you do that, that only tells you if the rear driveshaft is the vibe source. the rear diff will still be rotating so if that's where the vibe is then it will more than likely still do it even without the driveshaft.
Good Pont Keisur! I didn't think of that - it might make it worse to identify. I checked last night at 4:00pm and the Master Technician was searching the lot for stock size wheels to put on it to verify it was not brand new 33x10.5x15 BFG MT's on new Wheels...they have about 20 miles on them. That pisses me off, but maybe they will prove me and Discount Tire and BFG wrong on a good tire / mount / assy.
Old Dec 3, 2003 | 05:43 AM
keisur's Avatar
I'm not going to start in on my opinion of Discount Tire, that's a place I will never ever go again got anything! I got mine from 4Wheelparts last feb and they did a really good job.
Old Dec 3, 2003 | 06:48 AM
BigA's Avatar
Arrow
You said that you got your driveshaft replaced. But did you have it lengthened? I ask this because on CV jonits, allowing the shaft to be longer than stock can cause them to go out of phase. I have the same prob with my T100. As soon as I lifted the rearend 2" with add-a-leaves a vibration started. I believe it to be linked to the length of the rear drive shaft.
Andrew
Old Dec 3, 2003 | 07:09 AM
Ike's Avatar
Ike
Gee, lifting springs don't seem like such a good idea now.
Same problem. Same results. Maybe all these mods aren't such a good idea?
Old Dec 3, 2003 | 08:41 AM
  #25
keisur's Avatar
I doubt that. there are far too many people who have lifted and don't have these symptoms.
Old Dec 3, 2003 | 09:09 AM
  #26
Ike's Avatar
Ike
It seems like the vast majority of us with this vibration/hum problem have added lifting springs.
I'm going to an off road shop and a driveline shop and pick their brains. I'm thinking shim due to the change in suspension geometry on my rig.
So far I've only spent $73 on u-joints. I don't have himileage27 $$$ to throw at this problem.
I hope you figure it out
himileage27, that's gotta sting!
:pat:
Old Dec 3, 2003 | 03:51 PM
  #27
If you are having problems with vibration in the rear, and the only mod was to lift, than you rear differential needs to be tilted upward toward the Transmission mount by 4 degree's - 3" lift, and by 8 degree's 6" + suspension lift. I am chasing a vibration not directly to the lift, but rather in the drivetrain / tires / steering linkage etc... Point is, the lift is necessary to do what I do with the truck, and it wouldn't be worth having if I didn't do what I do with it - Offroad wheeling is to much fun.
Patrick
Old Dec 3, 2003 | 03:55 PM
  #28
:pat:
Yeah it stings - who said anything about having the money, I just had (past tense) room on the credit card. Its going to take me 5 years to pay this thing off. Thanks for the condolences though.
Patrick
Old Dec 3, 2003 | 08:10 PM
  #29
keisur's Avatar
Patrick
haha. I heard that. that's what I did 3 months ago when I got my front diff and rear 3rd from Randy's.
you preach the gospel!
BK2TFUTURE
Oct 11, 2015 08:42 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
