SCORE! Got a supercharger for $325!!
Old May 28, 2008 | 05:29 PM
  #41
doctorturbo's Avatar
you'll be able to run the stock pistons, don't worry about that.
your main concern WILL be air/fuel
Old May 28, 2008 | 05:32 PM
  #42
Texas_Ace's Avatar
Yeah, i know the Fuel is the real problem. That is why i will be getting the URD 7th injector kit to take care of that. And i already have a Short Ram Intake so air is as good as it can get too.
Then get a wideband and OBD scanner and i should be good to go for that.
I just don't want to have to open the engine again for a long time so if the spring ARE a weak spot I want to get those changed out now. Anyone know for sure one way or the other?
Old May 28, 2008 | 05:38 PM
  #43
mt_goat's Avatar
Originally Posted by Texas_Ace
Yep, an egine oil cooler, already and a tranny cooler. I think i might pick that up then.
Where did you mount yours? that is something i was thinking about and could not come up with a good place for it except in front of the radiator but the tranny cooler is already there....
It starts on page 23 here and goes to page 25:
https://www.yotatech.com/forums/f160...5/index23.html
Old May 28, 2008 | 06:32 PM
  #44
Texas_Ace's Avatar
Thanks for the link, lot of good info there, good to know that i am not even close to going overboard on cooling.
I read through a few pages, anything change since that thread? ever get your temps down?
Now i have lots of ideas to play with.
Old May 28, 2008 | 06:40 PM
  #45
mt_goat's Avatar
Just made post #665 today:
https://www.yotatech.com/50840375-post665.html
Old May 28, 2008 | 07:24 PM
  #46
netwt12's Avatar
check the bearing on the tensioner pulley. a friend of mine bought a supercharger for his 4runner that the seller stated needed to be rebuilt. he noticed that the tensioner pulley was almost frozen solid. he ended up with an operational s/c for $250 plus a new tensioner.
Old May 28, 2008 | 07:31 PM
  #47
Texas_Ace's Avatar
Yep, tensioner is A-ok as far as i can tell. Spins freely and smooth.
Going to try to open it up tomorrow and see what it looks like inside then i will know what kind of deal i got. I found a rebuild kit for $75 if the nose is really all that needs to be done.
Old May 31, 2008 | 08:38 PM
  #48
Texas_Ace's Avatar
Ok, so I am taking the Supercharger apart as i type and first off i am VERY happy with what i have seen so far. The oil was still perfectly clean and it looks mint inside.
I am trying to figure out how to take the nose bearing out, anyone know how to do it? I can't figure out what side i need to tap it out. From the pulley end? Or from the inside out?
Anyone know? Also, anyone know how to take the roots out? I don't think i am going to as everything looks so good i doubt there is anything wrong in there. Plus it spins SOOOO smooth.
So how do i get the bearing out?
Old May 31, 2008 | 08:59 PM
  #49
Texas_Ace's Avatar
Ok, quick vote, should i make a new thread for all my install technical stuff or just keep this one going?
Old May 31, 2008 | 09:08 PM
  #50
X-AWDriver's Avatar
Make a new thread so we can follow it easier.
Old May 31, 2008 | 09:18 PM
  #51
Texas_Ace's Avatar
Thats what i was thinking.... on the way.
Old May 31, 2008 | 09:48 PM
  #52
Texas_Ace's Avatar
Ok, here is a build up thread for my truck, all future updates will go here:
https://www.yotatech.com/forums/f2/t.../#post50842922
Steven.m.paulk
Jun 7, 2020 10:45 AM
LCE_Performance
Oct 1, 2015 01:03 PM
whiteyota93
Sep 29, 2015 02:31 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
