Sagging liftgate...
Old Apr 16, 2003 | 10:38 AM
Beachrunner's Avatar
Sagging liftgate...
Does anyone know of a good aftermarket supplier of gas liftgate supports? Of course the OEM supports are outrageously expensive!
Old Apr 16, 2003 | 10:48 AM
Corey's Avatar
Co-Founder/Administrator
Hi Daren, if you want factory, drop these guy's an email.
http://www.yotayard.com/
They might have a good set of factory ones in from a wreck, and be much cheaper than new.
Old Apr 16, 2003 | 10:58 AM
rimpainter.com's Avatar
A trick I read in a mag once
Another trick is to use a small hose clamp on each black shock body. Sometimes this works, and sometimes it doesnt. Depends on how bad they are.
Old Apr 16, 2003 | 11:15 AM
Corey, I thought about pulling some from a wrecked truck but I figured I'd be in the same shape I'm currently in. Does anyone know the life expectancy of those shocks? What causes them to fail? I feel certain I'm gonna end up banging my head on that hatch!
Old Apr 16, 2003 | 11:31 AM
Firefyter-Emt's Avatar
vice grips.. Or drill shaft for a pin You could always use the old GM trick.. and cut a broom handle..
Old Apr 16, 2003 | 04:54 PM
alanh's Avatar
Have you checked with your local autoparts store? The Schucks store I go to has some of those. Its anybody's guess if they have the right kind, but it might be worth a try. I don't have any experience with the quality, because I was looking for a light-weight one for a small pickup canopy and had to go to a canopy dealer to get that.
Blamalam
Mar 12, 2022 07:34 AM
punks_is_4x4
May 31, 2016 06:03 AM
89fourrunner
Feb 17, 2016 06:52 AM
MichaelKLerner
Oct 27, 2015 07:18 PM
Jake28296
Sep 3, 2015 04:58 PM
