Rust prevention
Old Jul 24, 2003 | 06:53 AM
AznSky's Avatar
Rust prevention
Ok, I drilled 2 holes on the inside of my front side fender for the cb mount in my hood, and I heard that this could cause rust, so what can I do to prevent it? I was told you could just buy something at wal-mart and like brush it on the hole and the inside and it would work?
Here's a pic of Tom's mount, same thing that I did. Hope you don't mind Tom.
Old Jul 24, 2003 | 07:19 AM
rimpainter.com's Avatar
Rob-
I have always used touch up paint on exposed metal, and never had a problem. Oh, and I am talking about when I lived in Seattle.
Old Jul 24, 2003 | 07:24 AM
Lucky's Avatar
Rust prevention
I've always used some stuff you get in the UK which is an Acid rust preventer. It supposedly changes the exposed steel and stops it rusting. Alternative may be hammerite.
Cheers
Old Jul 24, 2003 | 08:04 AM
AznSky's Avatar
Originally posted by <96 Runner>
Rob-
yea i was thinking that too, but then I remembered the whole point of sanding down that area was for ground for my antenna lol. Any other suggestions Christian?
Old Jul 24, 2003 | 08:17 AM
Lucky's Avatar
Rust Prevention
I always reckon on wiring a separate ground on an Aerial anyway to somewhere you can get at if the tin worm has it's wicked way where the aerial is mounted. That way you can always re make the earth. You can solder a cable to the body of the aerial and run this to a good and easy to get to earthing point.
Cheers
Old Aug 5, 2003 | 09:29 AM
AznSky's Avatar
any other ideas for rust? Cuz now the hood mount has scratched the paint off, and rust is starting to form on the side of my hood.......
Old Aug 5, 2003 | 09:41 AM
SLC Punk's Avatar
I would seal it with silicone and make an acutal ground wire.
Old Aug 5, 2003 | 10:30 AM
loosehead's Avatar
The only other suggestion I have is to move out to AZ fulltime, then you won't have to worry about it...
Old Aug 6, 2003 | 08:22 AM
Highland Runner's Avatar
For something like 2 small holes I usually paint with clear nail polish. The screws going in will cut through that though. After it is installed I would take off the plastic wheel well covers. Then coat the screws and hole with nail polish. When there is 2-3 coats put a big dab of that clear syn grease over the whole thing. You may also need to use a grounding wire from the mount to a good grounding point, unless its a non ground plane antenna.
Old Aug 6, 2003 | 08:25 AM
If you want to get crazy Rob, sand it, acetone it, prime it, paint it, and clear coat it.
Cant beat that seal. Just make sure to mask off the surrounding area really well.
Old Aug 6, 2003 | 08:29 AM
MTL_4runner's Avatar
A nice big blob of clear silicone works for me.
Use touch up paint for any visible areas.
Definately worth the time to take off the fenderwell and do something to the back side of the bolt
Old Aug 6, 2003 | 08:38 AM
AznSky's Avatar
Yeahh.....wha??? haha. I think I might just take off the fender wall and try the nail polish thing. I dunno. I will go to an auto parts store and see if they have any rust protection stuff.
If only I was as smart as you Christian.........(no sarcasm )
Old Aug 6, 2003 | 08:53 AM
gwhayduke's Avatar
3M has a product called "Rust Avenger" that chemically reacts with the rust and I believe turns it into a iron phosphide coating, kind of like "Parkerizing." I bought some at Pep Boy's years ago and use it every now and then on rock chips. It comes in a "pen" applicator that's suitable for small areas.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
urabus
Nov 10, 2015 07:38 PM
AustinTaco
Sep 18, 2015 08:58 PM
BimmerSage
New York
Sep 17, 2015 05:21 PM
presto30
Sep 15, 2015 09:41 AM
