Running Hot
Old Jun 10, 2007 | 03:47 AM
mt_goat's Avatar
Maybe its that radiator stop leak crap.
Old Jun 11, 2007 | 11:18 AM
jdt0t's Avatar
It wasn't the cap, replaced it and have the same results. When they do pressure test as they did at the dealer do they test to see if I have a leaky HG or do they test for a clogged radiator? I think they were going after the big $$ and looking for a HG problem. I'm going to replace the radiator this weekend. At least I won't have to worry about the cooling system for a while after all of this.
Thanks again
Old Jun 11, 2007 | 11:43 AM
Finelygotone's Avatar
They can't pressure test a partially clogged radiator - they tested your cooling system and HG for leaks..... Hate to say I told you so about the cap, but....
Did you go buy the $4 thermometer yet to check how your radiator is cooling?
Old Jun 12, 2007 | 07:45 AM
jdt0t's Avatar
I'm going to replace the radiator, if that doesn't work the water pump's next. At least I'll know the cooling system in and out after this.
Old Jun 26, 2007 | 01:24 PM
  #25
Any luck with replacing the radiator?
the1998sr5
15
Jul 14, 2020 08:35 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
HRDC0R19
Jul 5, 2015 06:43 PM
