Rubbing noise from front end
Old May 30, 2007 | 07:48 PM
Crazychopstick's Avatar
Thought I'd update on this issue:
I recently installed new tierod ends and new lower balljoints on both sides of the Runner. The "rubbing" sound has died down a bit but it still comes and goes on occasion, just barely.
Old Jul 27, 2007 | 06:55 AM
CBDenver's Avatar
Did all or any of the rest of you guys find anything that was causing this? I've got same thing and have been going thru the same list as everyone trying to figure it out.
thanks for the help.
Chris
1997 4-Runner 3.4L 4WD
Old Aug 2, 2007 | 09:12 PM
The last modification I did was poly steering rack bushings. After that the "rubbing" could clearly be narrowed down to high-speed right curves only.
I'm pretty much set that it's a bad front passenger bearing, but I'm riding it out for now.
Old Aug 2, 2007 | 09:39 PM
d0ubledown's Avatar
if it was louder on right sweepers than straight or left hand turns, then its a drivers side bearing..not PS.
Old Aug 5, 2007 | 09:04 PM
  #25
Right curves. As in the truck is following a road that is curving to teh right.
I figured that with the weight off the passenger side is when the bearings can freely "rub" or grind.
And it's not louder. The noise is ONLY present on those curves.
MTLroadierunner
Jul 15, 2015 12:58 PM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
Jonny246
Jul 12, 2015 04:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
