RPM Problems!!!!
Old Aug 20, 2006 | 03:51 PM
NX Tacoma's Avatar
RPM Problems!!!!
Hi everybody, its been awhile since I have chatted with you!!!!
I hope everybody is doing well!
My problem is I have a 03 Taco (3.4) and when its in D-drive my RPM's are at 400(idle). When I turn on my A/C in D-drive, its goes to about 500 RPM's. Sometime while I am driving it idles VERY rough, like it wants to die!!
If you think its the a timing problem, how can i adjust the timing on it?
Do any of my Yota Tech Pro's have any Idea what the problem could be??
Old Aug 20, 2006 | 04:52 PM
Firefightertaco's Avatar
have u tried cleaning the intake, i did it on mine and it seems like it idles a lot better now
Old Aug 20, 2006 | 05:41 PM
MTL_4runner's Avatar
Did this happen all of a sudden, or gradually over time?
Any other info surrounding the circumstances would be helpful for diagnosis.
Old Aug 23, 2006 | 09:24 PM
NX Tacoma's Avatar
FFT
I already tried to clean the intake with SeaFoam and it did help a bit....but not to much! Great input! Thanks!!!!
MLT 4R
It happened out of the blue!
I wonder if it my fuel pump slowly going bad?!?!
Thank you for the help!
Old Aug 23, 2006 | 09:26 PM
NX Tacoma's Avatar
How can I check the fuel pump/fuel system to make sure thats not my problem?
Would cleaning the carb wih carb cleaner help? I guess it worth a try!!!!!
Old Aug 23, 2006 | 09:33 PM
Tanto's Avatar
You don't have a carbeurator in that engine.
Old Aug 24, 2006 | 05:24 AM
Ironmike4x4's Avatar
I've not done it on a Toyota, but hopefully someone else can guide you through it. Get a fuel pressure guage and hook it up and find out what the specs are for your vehicle and diagnose accordingly. Hopefully somone who has done this will chime in. Cleaning your carb wont help at all, since you dont have one. It's fuel injected thankfully
Old Aug 24, 2006 | 04:20 PM
NX Tacoma's Avatar
Opps!
I was thinking about using carb cleaner to clean my throttle body.
When I removed my intake(aftermarket) to clean it, I could see "carbon" in the throttle body.
Sleaker
Aug 26, 2020 06:03 AM
PlayAwhile
Jul 20, 2015 11:36 AM
kyletbert
Jul 17, 2015 11:39 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
