View Poll Results: which rotor type
blank
45
67.16%
xdrilled+slotted
22
32.84%
Voters: 67. You may not vote on this poll
Which rotors for me?
Can you switch to new rotors without changing the pads (which still have a good amount of life left)?
I know that you are supposed to turn the original rotors if you need new pads.
Thanks guys,
J
Hope your new brakes are ok Kevin.
Thanks guys,
J
you can physically jsut change the rotors, but why... if there is an ireegular wear pattern alreayd on the current pads that cant be seen with the naked eye, it will screw them up or prone the new rotor to wearing prematurely....
if you are replacing it, do it right and replace both, even if you have the rotors turned, you replace the pads at the same time with new ones
drilling holes can have adverse effects on the structural integrity of a rotor. i guess slotted can help dissipate heat faster, somewhat. i have the brembo rotors and performance friction pads, they perform great, much better than the stock setup!
#25
Originally Posted by bryanr
I just picked up a set of Power Stop cadmium plated drilled rotors off Summit racing. Very nice piece of equipment. I am redoing most of my brakes, including extended Pro-Comp stainless steel lines and Hawk HP pads.
#26
I have Stillen cross drilled rotors and Metal Matrix pads (F/R) on my JGC. They are great.
I have slotted Power Stops on my 4Runner. They also work great.
I'm a believer in getting the gas out from under the pads. Simple physics.
Also simple physics is that there is less braking surface area when using slotted/CD'd rotors. In the real world, my experience has been that getting the gas out outweighs the lack of braking surface area.
#27
How much did your combo run you for?
#29
lemme give you my rotors history.
i used to have the worse warping rotors. almost every year, they would go warped. it was like a schedule. after the 2nd or 3rd set of replacements (after some turnings on them), i finally sucked it in and got cross drilled brembos.
that was like 6 years ago. now, like after 2 set of pads, i have YET to see any symptoms of rotor warpage.
now on my STi, i have seen one issue that i thing a set of crossdrilled or even the slotted one will help me.
when it rains and water gets in between the pads and rotor, and i hit the brakes, i feel like i have NO BRAKES. i cant wait till rain season to replace them with some cross drilled ones... i saw a nice set of MU PROJECT rotors for the STi that looks really cool too...
#30
Originally Posted by kevin444
Brembo Blanks thats are cross drilled and slotted.
I do tend to drive fast but im worried about brake pad life and dust and well overall integrity plus best performance
info i got on mine, was brembo CASTS the holes in them.
kinda like donuts are made with holes, not some machine cutting a hole in them after coming out of the oven.
i was warned about a cracks forming. but after putting in the second set of pads, i checked them and no visible cracks...
just my 2 cents...
#31
+1
before my STi, i had a WRX. and this one exit off the freeway that i had taken a million times with my 4runner, i didnt feel as good as with the WRX...
(okay, with the STi with the massive brembo calipers, when dry, it's a little diff issue... lol.....)
#33
Those Power Stop Cad ones look alot like the DBA rotors out of Autralia.
But they work great. The new lines, pads and rotors were installed last week when my 4" lift was done. I had a frozen caliper also, fun stuff. The truck brakes great now at least!
#34
Originally Posted by TACOMANATOR
Cross drilled roters tend to develop cracks between the holes. Slotted vent gas from under the pad. Slotted or blank would be my choice.
#38
Originally Posted by jodynich
Bump for an old subject. I've had my rotors warp twice (on the second time right now) in the last 4 months and i'm sick of it. Should I just get brembo blanks?
i just had the tires removed on the fronts and i swiped my knuckle on the rotor surface.
smooooth....
and this is like 5-6 years into it. no maintenance other than 2-3 sets of pads and 1 complete fluid swap.
best part? NO MORE WARPAGES!!!!!!! (crosses fingers and knocking on wood)...
#40
read my earlier posts.
i used to have warpage problems every 8-10 months. no matter what i did. OEM rotors.
i bought my own torque wrench specifically for the lugnuts (one of the leading causes of warpage issues).
after the 2-3 rotors replacements with OEM stuff and when the last one could no longer be "turned," i went ahead and "splurged" for back then $90 per rotor (told ya it was like 6 or so years ago... lol)...
i smile now when i read threads like these... :evil smiley:
make sure to get cross drilled ones that are made with the holes in it, instead of drilling holes AFTER they are made...
