Road Less Traveled link? I want to jam bigger tires on
Old Sep 16, 2007 | 08:54 PM
BOSTON4RUNNER's Avatar
ok
my signature described what I have currently
what is the biggest size tire I can fit by doing some cutting?
I remember the article titled the road less traveled about a 4 runner that they jammed big tires on...I might do something similar but want to read that article first
I currently have 285 75 16's
if I go with a wheel that kicks it out a little more, that can I fit on my truck in its current set up - lift wise etc. Any recommedations on wheels? who makes something cheap in a steel wheel that will kick it out another inch or so?
I will do gears as needed
thanks!
Old Sep 16, 2007 | 10:02 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I think you're talking about Trails Less Traveled (TLT) and there was a thread on here about fitting 35's with only a 2" body lift
Old Sep 17, 2007 | 07:30 AM
Bennito's Avatar
Chris (Ravencr) fit 285s with 0-1" of lift (don't remember exactly) (then he lifted and ironically had more issues than before).
I think sonoran steel steve fit 35s (315/somethings, actually) with 2" suspension lift and 1.5" body lift. maybe it was 2.5" suspension lift.
Old Sep 17, 2007 | 07:35 AM
terryjmatthew's Avatar
You can go 35's but it is going to take a substantial amount of cutting and 4.5"? backspaced wheels. Here is the link for you.
http://www.trailslesstraveled.com/news.php?id=48
Old Sep 18, 2007 | 05:36 AM
I am going to send my UCA's to Sonaran or whatever his name is for the modification to free up some clearance
Old Sep 18, 2007 | 06:53 AM
BajaRunner's Avatar
Good luck with that. Post pictures when your done.
Pray for surf.
Old Sep 18, 2007 | 01:58 PM
d0ubledown's Avatar
why ditch the LC's for heavy steelies that stick out? youre going the wrong way...
to fit 35/12.5's you'll need at least 1"BL, shaved arms or 1.5" spacer or 3-3.5" BS wheels, and 4.88's. plus some cutting and pounding of the pinch weld area.
Old Sep 18, 2007 | 06:43 PM
I do have a 1 invh body lift plus 3 inch suspension lift
I already have cut out the fender bottom and pinch weld is gone - this was an earlier mod
How do the shaved A arms work? no problem at all? I have a spare pair so think I should send them out and have them modified, then toss them in
think I will be safe for a 35 12.5 at that point?
thanks
Yota.Jay
Oct 24, 2015 08:41 AM
Sep 4, 2015 09:27 AM
Michael oaks
Jul 27, 2015 11:47 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
