Rims from Wheeler's Off Road
Old May 13, 2003 | 12:35 PM
1WiCkEd_RuNNer's Avatar
The reason 15" rims are better for wheeling versus 16" rims is simply "the bead", or the lack of the bead on the 16" rim! The 16" rim has no bead! So airing down becomes very dangerous! That is why wheeling on 15" rims are better!!
Old May 13, 2003 | 02:14 PM
keisur's Avatar
For "die-hard" wheelers anyway, for me it would be the price difference between the the two tires. I don't wheel enough or hit enough extreme terrain to require an air down to, say, 5-10 psi so it makes no diffence to me.
Old May 14, 2003 | 05:09 AM
beachtaco's Avatar
are you sure? i think you're getting 16.5" mixed up with 16". the 16.5" don't have a bead lip so airing down can be dangerous. 15" and 16" have a bead and can be air down fine.
in terms of off-roading, 15" are better because you have more tire bulge when you air down. and most of the time, 15" tires have less thick sidewalls so they will "fold" around objects better.
in terms of off-roading, 16" can be better because of the thicker sidewalls eventhough they won't bulge as much as a 15".
in terms of on-road, 16" have a greater load range and suppose to handle better on the road since the sidewall normal has a smaller profile than a similar size 15" wheel.
btw, nice 4runner.
Old May 14, 2003 | 05:12 AM
beachtaco's Avatar
Originally posted by keisur
[B]I agree. Here's some pics of my rear with the mud guard and without it. We have contact. yep. the front is fine and that's where I was most worried about rubbing before I installed my lift. I don't want to get the sawzall out after it either so the next set will be 265/75's.
nice flex pics. i'm in the same boat, i got about 2.5" of lift and haven't decided if i'm going to 265/75R16 or 285/75R16 due to rubbing. i really like to avoid a body lift unless i plan to do alot of trimming to clear 315/70R16.
Old May 14, 2003 | 05:42 AM
  #25
RTdawgs's Avatar
Originally posted by its2slo
the rock crawlers from 4wheelpartsphux dont clear the big front brakes on tacos/3rd gen runners without 1/4" wheel spacers.
if youre referring to Tech 1 wheels youre totally wrong. i can think of 5 guys who run these without spacers.
  #26
keisur's Avatar
I thought the same, could have sworn I saw a bead on mine before the guys mounted them.
Old May 14, 2003 | 06:29 AM
  #27
Flygtenstein's Avatar
Wrong.
15, 16, and 17 inch rims have the same safety bead.
16.5" do not.
Wouldn't you think that if 16" rims had no bead that all of the people who wheel their 3rd Gens with 16's would be hunting for beadlocks?
Old May 14, 2003 | 07:06 AM
  #28
TDiddy's Avatar
Originally posted by Flygtenstein
Wrong.
16.5" do not.
I'm glad you guys could straighten that out for me, it just didn't make sense that a rim offered by Toyota wouldn't have a beadlock!
Old May 14, 2003 | 07:30 AM
  #29
keisur's Avatar
mertztr, did you mean to say "beads?" "beadlocks" are the ones that have screws holding the tire.
Old May 14, 2003 | 07:32 AM
  #30
TDiddy's Avatar
Oops, yes you're right. I meant to say beads. Lemme go get that cup of coffee now...
1uzRunner
63
Nov 10, 2018 03:58 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
potatopants
Sep 15, 2015 06:26 AM
AkitaDog
Sep 3, 2015 09:01 PM
