resetting the ecu
Old Feb 7, 2008 | 02:58 PM
Y2Krunner's Avatar
resetting the ecu
I am heading out on a road trip tomorrow- having some crappy mileage issues and am going to go ahead with a MAF cleaning tonight. Am i risking anything by resetting the ECU before going on a crappy, cold mountain pass road trip? What i am asking is if there are possibilities of problems by doing so- i want to know.
Old Feb 7, 2008 | 03:40 PM
X-AWDriver's Avatar
No,you should be fine. Just do a little driving around town before you go.
Old Feb 7, 2008 | 03:42 PM
MTL_4runner's Avatar
Clean the MAF with brake cleaner, pull the negative battery cable for 5 mins, reattach and have a nice trip.
Old Feb 7, 2008 | 03:45 PM
Texas_Ace's Avatar
They have MAF cleaner as well that if you have to buy something anyways would be a good idea. Seeing as a new MAF is $$$. Brake cleaner will work fine though, just be careful with the MAF.
Old Feb 7, 2008 | 03:48 PM
4rx's Avatar
4rx
I would just pull 20a EFI(fusebox next to the battery) for a couples mins before start it.
Old Feb 7, 2008 | 03:51 PM
Texas_Ace's Avatar
There is no reason for that, disconnecting the battery works fine. I have done it many times while i was installing my MSD.
The only reason for the above would be if you didn't want to lose your radio settings and clock.
I would personally pull the battery, that way there is no chance of messing up that fuse or something with it.
Old Feb 7, 2008 | 03:56 PM
4rx's Avatar
4rx
I thought pull the fuse is much easier than disconnecting negative battery.
Old Feb 7, 2008 | 04:00 PM
Texas_Ace's Avatar
LOL, that it might be but for that few extra seconds i would personally rather know that everything has been cleared out. Plus messing with fuses while 95% time is perfectly fine with these fuses if somethung causes it to blow you can't just get another fuse, those are hard to find.
Old Feb 7, 2008 | 04:22 PM
Just an FYI.....the techs at the Toyota dealer use good old brake cleaner 99% of the time to clean MAFs
Old Feb 7, 2008 | 04:33 PM
4rx's Avatar
4rx
Yeah, that is mostly like never gonna happen, anyway lol
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
matt1833
Sep 16, 2015 07:11 AM
