Removing the inside panel on Rear Gate of 4 runner
Old Jul 25, 2003 | 12:01 PM
MrBob's Avatar
The lock has shifted on my rear gate on my 97 4 runner and I wonder if anyone knows how to access it so I can reset it back in the slot...sounds confusing ,eh? the slot I insert my key into has come loose from the body of the rear gate and I need to get to it to re-attach the lock in it's position...how do I get into the panel space to access the lock mechanism to repair it? it is located on panel above the rear license plate..............
Old Jul 25, 2003 | 02:21 PM
Bob_98SR5's Avatar
MrBob,
Ask Jacksonpt. He recently did some repair work on his rear tailgate about 2 montsh ago.
Bob
Old Jul 25, 2003 | 11:04 PM
butnut's Avatar
A small PITA. It's all done from inside. Pry off the tiny panel cover from the pull down strap. Unscrew the handle. Pry the plastic panel (inside) off the tailgate. Lift up to release the rubber top trim. Shimmy it out easy. Now, you'll see a big metal panel...all those screws come out. You can access the garnish and guts from there. There will be a few wires/connectors stuck on the metal panel. I just hung the panel off the tailgate with a long bungee. Good luck.
4x4-runner
Feb 26, 2017 06:42 AM
cchinny
Jun 25, 2015 08:11 PM
4runnerx3
Jun 24, 2015 01:44 PM
JaredL
Jun 16, 2015 04:47 PM
HBoss
15
Jun 20, 2002 05:28 PM
