Relentless CEL. Multiple misfire
Old Oct 4, 2013 | 05:18 AM
1371engineer's Avatar
2001 Tacoma ext cab 4x4 TRD 3.4l 216k Mi.
Replaced-timing belt
water pump
all other belts, tensioners and bearings
replaced clutch
replaced all coil packs
spark plugs- ngk
plug wires-ngk
replaced battery and terminals
new air filter
cleaned MAF and throttle body
cleaned fuel injectors
changed oil and filter, trans fluid, flushed radiator
At first check engine light came on. Came up with misfire in every cylinder. Replaced timing belt water pump plugs and wires. Light came back on after i put everything back together. Pulled the codes again. Still have a misfire in cylinders 2,4 and 6. I have no idea where to go from here. what could cause a misfire on one side of the motor.
Old Oct 4, 2013 | 05:58 AM
By the way after driving for a little while the check engine light starts to blink. could be wrong but doesnt that suggest that the cat is getting to much fuel? which makes me think that mabey it could be the o2 sensors. to my knowledge they have never been replaced. My next question would be could the o2 sensors fail and not give me a code for the sensor itself and just give a misfire code. Would a bad o2 sensor even cause a misfire?
Old Oct 4, 2013 | 09:34 AM
paddlenbike's Avatar
Did this start after a timing belt replacement? It sounds like the cam timing on one bank of cylinders is off, i.e., the cam gears are not properly aligned on the timing belt.
Old Oct 4, 2013 | 10:08 AM
Prior to replacing the timing belt i had a misfire on every cylinder. After the timing belt replacement it came up with the misfire on cylinder 2 4 and 6 only. i was sure to align the marks with with the belt/ camshaft and everything. if i just use a timing light to check the timing, will that tell me if that one side camshaft is off.
Old Oct 4, 2013 | 10:32 AM
rworegon's Avatar
No, the timing light only tells what the crank timing is and not the individual cam timing.
Did you turn the crank bolt 2x clockwise to be sure all the timing marks lined back up after releasing the tensioner?
Old Oct 4, 2013 | 01:13 PM
Def didn't do that. It was my first time and just had to go off what I have read. Missed that part about turning it afterwards
Old Oct 4, 2013 | 02:32 PM
rworegon's Avatar
Did you find this thread? The link in post one is very good tutorial.
Old Oct 4, 2013 | 03:58 PM
Kiroshu's Avatar
Miss fires on a single cylinder bank...
Suspect incorrect timing belt installation as well.
Ignition cables(spark plug wires) installed correctly...?
Old Oct 4, 2013 | 04:07 PM
Yea I'm afraid I'm going to have to tear it all back down an check. Plug wires are def Installed right. I used the same diagram
Old Oct 5, 2013 | 03:15 AM
Texas_Ace's Avatar
Ditto the rest, wrong timing on a bank is my first guess as well.
Old Oct 9, 2013 | 05:30 PM
rworegon's Avatar
1371, did you get this issue resolved?
shooter86314
Jan 7, 2016 07:05 AM
the_supernerd
Oct 1, 2015 09:20 PM
larrys93pickup
Sep 17, 2015 07:05 PM
