Rear window down problem
Old Aug 6, 2003 | 05:29 AM
emplusten's Avatar
This is strange...
I have a 2002 SR5, no alarm. I bought a new keyless entry remote, and programmed it. The rear window down button on the remote works fine.
But now the rear window control on the dash does not work. I can still raise and lower the window using the key on the liftgate.
Any thoughts?
Thanks - Bob
Old Aug 6, 2003 | 07:29 AM
Bob K's Avatar
Make sure the window lock button is not activated, when it is the only way to raise and lower the window is with the key or remote.
Old Aug 6, 2003 | 08:18 AM
emplusten's Avatar
I'm an idiot!
Bob K - Thanks.
I must of hit the window lock button this morning when I programmed it. I actually never knew the window lock button affected the rear window.
Old Aug 6, 2003 | 08:21 AM
Bob K's Avatar
I only found out because my wife hit mine and the next time I drove it I used the remote to lower the window and tried to raise it with the switch and it would not go up. At first I thought the motor was bad or something till I tried the key and it worked. Checked the lock button and when I turned it off it worked. When the lock is on the drivers window is the only one that goes up and down.
Old Aug 6, 2003 | 08:49 AM
Mack's Avatar
Don't feel bad..
I remember over on 4x4wire a couple of years ago someone had he same problem and wound up tearing the who system apar rying to find the fault.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
