Rear window??
Old Dec 10, 2003 | 05:21 PM
wyldrs's Avatar
Rear window??
My rear window on my '91 runner will not go all the way up! Is there a certain way i should go about lubrucating it??
Thanks.
Old Dec 10, 2003 | 05:53 PM
95_4X4Runner's Avatar
I sprayed STP silicon spray into the channels of all my windows to make them move better.
You may have more serious problems, and may want to take apart your tailgate and check out the operation of the window regulator, and maybe clean out the old gunked up grease, and put some new stuff in there.
Old Dec 10, 2003 | 05:56 PM
Leaf's Avatar
I had some problems like that on my '94. Easy to diagnose:
Remove rear panel (pry gently with fingers)
Carefully unpeel plastic sealing
Inspect!
I had a couple of rusty rails back there. I'm always leaving my window partially down and water tends to fly in quite a bit.
Replaced the rails, cleaned out the rust chunks and it's as good as new.
Hopefully, yours is just binding or a support for one of the vertical rails came loose. Easy to oil and get to again if necessary.
Good luck!
-Leaf
Old Dec 10, 2003 | 07:17 PM
fooddude's Avatar
mine did that for a little bit it started coming off the tracks so i just popped it back in.
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
