Rear suspension OME 890 or 891
Old Feb 20, 2006 | 02:40 PM
JHupp's Avatar
Don't know about the 882s, but the 890s or 891s will work fine in the back. Supposedly on the TTORA forums, the 882 is just the 882 stretched out more(no extra coils) and from what I've heard, a lot on their is that they tend to sag almost an 1" at times. Don't know if any of you have had this problem, but a few guys there that I talked to all reccomended an 881 with spacers over the 882s any day. Just my .02
Old Feb 21, 2006 | 04:51 AM
MTL_4runner's Avatar
This is true, the 880, 881 and 882 all have the same spring rate (500 lbs/in), same number of coils (10.2) but are just different lengths (365, 375, 385mm). So I'd agree that it is probably the best setup to run the 881s with the appropriate spacers to get the lift you're looking for.
Old Mar 7, 2022 | 07:30 AM
Chelu's Avatar
How man inch lift 881 and 891
Originally Posted by MTL_4runner
It won't be that bad with the 891s and if you really want 3" of lift in back that would be the way to get it (you could use spacers too). I have 881s in front and 890s in back so it may be close to the same up front if you are going with 882s and carry 125lbs extra on the front. It really is a tossup.....the biggest unknown is what final lift you are going to get up front. Maybe order both sets (890s and 891s) and then put in a set after you install the fronts. My hunch is that 891s would probably sit an 1" higher in the rear and the 890s will be very close to dead level (depends on what look you are after).
I wanna change out my oem spring to heavier duty ones.I’m planning to use front 881 and rear 891. What’s the inches on lift on these springs been reading everyone has different answer on lift. I’m currently running spacers 1” front and 1.5” rear it sits leveled. But adding weight make it sag in the back. Also planning to go bigger tires 33s. Would 881 and 891 be perfect? I’m looking to go 2-2.5 front and 3”rear
alcarames
Feb 3, 2010 12:03 PM
patrickryanb
Oct 13, 2007 06:12 AM
ORB
Mar 15, 2005 12:42 PM
tarheelrunner
Aug 19, 2004 05:16 PM
04Tacoma4x4
May 28, 2004 06:32 AM
