Rear suspension OME 890 or 891
Don't know about the 882s, but the 890s or 891s will work fine in the back. Supposedly on the TTORA forums, the 882 is just the 882 stretched out more(no extra coils) and from what I've heard, a lot on their is that they tend to sag almost an 1" at times. Don't know if any of you have had this problem, but a few guys there that I talked to all reccomended an 881 with spacers over the 882s any day. Just my .02
How man inch lift 881 and 891
It won't be that bad with the 891s and if you really want 3" of lift in back that would be the way to get it (you could use spacers too). I have 881s in front and 890s in back so it may be close to the same up front if you are going with 882s and carry 125lbs extra on the front. It really is a tossup.....the biggest unknown is what final lift you are going to get up front. Maybe order both sets (890s and 891s) and then put in a set after you install the fronts. My hunch is that 891s would probably sit an 1" higher in the rear and the 890s will be very close to dead level (depends on what look you are after).
