Rear parking break removal
Old Dec 11, 2004 | 04:15 PM
minidisc8's Avatar
Rear parking brake removal
I am trying to replace my rear axle seals on a 95 4Runner and cannot figure out how to remove the rear parking brake from the wheel housing.
It is a hose type fitting on either side that I cannot figure out how to remove.
Does anyone know how to get this detached?
Sorry the picture sucks...
Old Dec 11, 2004 | 05:25 PM
minidisc8's Avatar
Anybody?
Old Dec 12, 2004 | 01:17 PM
Flamedx4's Avatar
The park brake disconnects just by popping a clip from the cable end.
The "hose" is the brake line.
See if this helps:
Old Dec 12, 2004 | 03:22 PM
minidisc8's Avatar
See if this helps:
Thanks for that but mine is set up differently since it is a '95. I am having a problem figuring this out since all the write-ups are geared towards older vehicles. I know this isn't the brake line b/c i've already taken that off, this is a connection for something else.
I will try to get a better picture in the next day or two.
Old Dec 12, 2004 | 03:39 PM
Cebby's Avatar
I have a pic somewhere from when DMG and I did my ARB's. Let me see if I can scrounge it up.
Old Dec 12, 2004 | 04:12 PM
Flamedx4's Avatar
You're pic didn't load before. Your's isn't different because the year (the 89-95s are supposedly the same) but maybe because it's a 4Runner? I wonder why it would be different than a truck, I have rear ABS too.... Anyway, I can't tell what that is in the picture, it's too close up to get a frame of reference. Sorry, I tried.
Old Dec 19, 2004 | 08:45 PM
minidisc8's Avatar
Finally figured it out
Well it turns out that you have to get to this little bugger from the inside. So, after taking off the outer part of the drum I was able to remove two 10mm screws and detach the end of the spring and feed it out.
I have two pictures. The first is looking down on to the wheel where you can see the "hose/spring" goes into the drum.
The second shows the inside looking from the side.
Thanks to all who offered help.
Charecter1
Nov 6, 2023 10:08 AM
mengquis
Jul 13, 2015 10:39 AM
hangtown88toy
Jul 10, 2015 02:33 PM
ItsJustD
Jul 7, 2015 07:49 AM
skoti89
Jul 6, 2015 07:45 PM
