rear heater
Old Feb 27, 2005 | 11:32 AM
ajz399's Avatar
rear heater
what would cause my rear heater to only blow cold? 1994 4runner.
Old Feb 27, 2005 | 11:42 AM
waskillywabbit's Avatar
What type vehicle?
I imagine either your lines aren't getting hot fluid from the engine or you got a bad t-stat...does the front blow heat?
On my 85 the front/rear heat are all plumbed into the same lines off the engine bay. Follow your rear heater lines back and see if they are getting warm when the temp gauge gets up hot enough where you should have heat.
Good luck.
Old Feb 27, 2005 | 11:45 AM
ajz399's Avatar
my front heater works great, back heater has no heat at all
Old Feb 27, 2005 | 11:46 AM
eric-the-red's Avatar
I would guess either blocked line to the rear, or the control valve is stuck shut.
Old Feb 27, 2005 | 12:15 PM
ChickenLover's Avatar
Turn it on and let it go for about 15 min. The first time I used mine it was cold too, but eventually got hot. It takes a while for the coolant to work it's way back there I guess.
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
94 Newbie
Aug 6, 2015 10:33 AM
Logz808
Jul 26, 2015 07:09 AM
