Rear Diff Breather height?
Old Jan 5, 2004 | 07:12 PM
TaterN's Avatar
No dice from search.
Does anyone know a safe water depth you can travel through without it reaching the stock breather?
I have yet to do the breather mod (extention). But I may be faced with having to do such a thing this week from the Ohio River backing up across part of a 900' driveway to my home. It's along a fenceline so I'll have a good idea of the depth.
BTW- I won't have the 4runner til tomorrow or I'd go measure it, if I can find it.
Thanks
Old Jan 5, 2004 | 07:20 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
It can reach about 18" deep. Good rule of thumb is don't go deeper than the center caps on the wheels.
Old Jan 5, 2004 | 07:29 PM
Robinhood150's Avatar
It's not that you absolutely can't go through deep water, it's just cheap insurance incase you do. If the stock breather is working like it's supposed to, then you should be fine. It's when there is junk preventing the cap from closing that is the problem.
Old Jan 5, 2004 | 07:33 PM
INsr5runner's Avatar
That, and if your gear oil is very hot, and you take a dip, the rapid cooling will cause the breather to open, thus allowing water in. and water will grenade your diffs.
Old Jan 5, 2004 | 08:13 PM
toy283's Avatar
Eh, my breathers don't operate that way. Just the opposite in fact. Rapid cooling of the gear oil and air in the differential causes contraction, sucking into the diff. The breather is designed to prevent this. It's sort of a check-valve, it allows pressure to excape, but closes under a vacuum. This is theory of course. One little grain of dirt can shoot that all to hell.
FWIW, with my current remote breather setup, I need to ford water deeper than 6'3" for water to get in. It'll get in the transfer cases (3'2") and engine (4'6") long before that. Higher is better.
Old Jan 5, 2004 | 08:24 PM
Yeah, it's the other way around...vacuum closes the valve.
Old Jan 5, 2004 | 08:28 PM
you guys are right sorry. maybe I should have reread what I posted...:pat: I guess it's time to
Old Jan 5, 2004 | 08:39 PM
WATRD's Avatar
Of course, there is another risk with the stock breather, whether it is in the stock position or raised.
When the stock breather is working properly, the axle develops a pretty strong vacum in it. When you immerse the axle, there is a vacum on one side of the axle seal and water pressure on the other That *can* cause a leak. Then there is the obvious, the breather getting a speck of dirt in it and failing to seal properly
Old Jan 5, 2004 | 08:51 PM
toy283's Avatar
That's why I won't use a stock breather on my wheeling rig. Mine is just vented to atmosphere to prevent both overpressurization and vacuum.
Old Jan 5, 2004 | 09:02 PM
WATRD's Avatar
I have a glass-bodied, rebuildable, fuel filter in the engine compartment for each of my breathers. That vacum was making me nervous.
Old Jan 5, 2004 | 10:26 PM
Me too.
Old Jan 6, 2004 | 05:04 AM
TaterN's Avatar
Thanks guys. As expected, far more info than needed, but just as well appreciated. I didn't realize there were many variations to the standard breather mod extention.
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
jaretstuff
Aug 4, 2015 02:08 PM
scottyg486
Jul 19, 2015 05:34 PM
Nickdigg
Jul 7, 2015 06:04 AM
