Rear Coil Spacer.
Old Nov 14, 2002 | 04:42 PM
Brad's Avatar
Question Rear Coil Spacer.
Are rear coil spacers for 2nd gens good? Will I need longer shocks. I am just curious. Probably going to go with 1.5" Downey springs instead.
Old Nov 15, 2002 | 10:36 AM
Beowulf's Avatar
Re: Rear Coil Spacer.
You are right, if I were you I would go with Downey Coils. IMO they would perform better than spacers.
Old Nov 15, 2002 | 10:42 AM
Corey's Avatar
Co-Founder/Administrator
If you go with the Downey HD coils like I have, they will net you around 2" or so in the rear.
Stock length shocks will be fine.
You don't need the longer shocks until you start adding the 1.5" spacer to the Downey coils, and that is not really needed unless you plan on running 33" or bigger tires.
You can run 32" tires with the Downey HD's, and a T bar crank.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
terminator
Jul 27, 2015 07:13 PM
Vargntucson
Jul 4, 2015 12:15 PM
