rear brake necessity after axle seal replacement
Old May 18, 2006 | 09:44 AM
Lone4runner's Avatar
I am doing my rear brakes this weekenend and wanted to know if I change just the shoes after gear oil has spilled onto it would that be ok? Or would I have to change the drums and the springs and stuff?
Old May 18, 2006 | 09:52 AM
984RNR's Avatar
i changed mine after the axle seal went about 45000 miles ago and only did the shoes and it has been fiine so far.
Old May 18, 2006 | 10:48 AM
eric-the-red's Avatar
Just change the shoes, they soak up the gear oil. The drums will be OK with a good cleaning.
Old May 18, 2006 | 10:58 AM
4runner4life's Avatar
Yeah, I just changed mine after my seals leaked and froze up the rear breaks which caused the wheel cylinder to start leaking fluid. Havent seen any problems yet but make sure you replace/refill that gear oil as well . . . keep your breather clean.
Old May 18, 2006 | 11:00 AM
midiwall's Avatar
Yeup... 2nd'd.
Use brake cleaner to loosen up the oil from the drums, wipe 'em down with a rag and you'll be find.
Actually, if you got goo all over the brake assembly (sounds like it since you're asking about the springs as well) then buy a couple of cans of brake cleaner and waste one spraying down the whole assembly (1/2 on each side).
Old May 18, 2006 | 12:45 PM
nice thanks for the advice guys
Aleeex_u
Jun 5, 2016 06:52 PM
voiddweller
19
May 2, 2016 09:10 PM
DanStew
Jun 29, 2015 10:46 AM
miceal383
Jun 29, 2015 12:27 AM
cchinny
Jun 25, 2015 08:11 PM
