Ready to pull the trigger on the t-15!
Old Sep 2, 2004 | 12:21 PM
amorphous's Avatar
Nice stuff...we must be t-15 twins!
I unpacked my @ lunch - clean and blem free -all the hardware LOOKS to be there.
Now, install....looks to be straight ahead...Can't wait to have this baby bolted up!
David, looks good re: outer hoop removal - I'm taking it that wasn't a sawz-all and rattle can fix?!?!?!
Ääron
Old Sep 2, 2004 | 12:36 PM
Mad Chemist's Avatar
Pretty close actually, i used a cutting disc to remove most of the hoop, then an angle grinder to grind down what was left, and painted with good ol' spray paint. Can't even tell they used to be there.
The install is pretty straight forward. I did mine myself, but it would have been nice to have someone hoist the bumper up when trying to bolt it to the frame brackets.
Old Sep 2, 2004 | 01:08 PM
amorphous's Avatar
nice re: the removal - looks kinda ARB-ish now - i like it!
re: install - nothing to cut or funny stuff so I understand (>?) I will have someone there to gawk, I mean help me lift it onto the brakets. I think my 6 year-old daughter should be able to turn the bolts while I stand back and supervise...I mean, make sure it's straight!
åÄrÖñ
Old Sep 2, 2004 | 01:43 PM
mt_goat's Avatar
Originally Posted by amorphous
Jackson....wow! looks awesome....now, was the TJM bumper able to be lifted up to fit your gap w/ that 2" BL? IIRC, they can be lifted...but not so w/ the ARB bumpers?
Now, if Mike at xtreme will just back to me....!
Å
Here are some pics of the modification I made to my T-17 for a 1 inch BL.
http://community.webshots.com/photo/...57661283SOWwBn
http://community.webshots.com/photo/...57661333bXQtzC
http://community.webshots.com/photo/...57661785NawhBf
http://community.webshots.com/photo/...57765684BgLUnQ
I also recommend replacing the bolts that TJM sends you to hold the bumper to the mount with grade 8 bolts, nylock nuts and star washers and torque the hell of of them. The star washers will grip and help keep the bumper from slipping in the adjustment slots. (tip) Use a 1/2" drive u-joint and 1/2" drive extensions through the turn signal openning to get maximum torque while a buddy holds a wrench against the frame. Those bolts must be tight enough to prevent slipping of the bumper/mount union. This is especially true if you are winching or in a accident. The bumper itself completes the "box" of support around the mount and if the bumper/mount union slips the mount could bend or twist.
I also recommend using a snatch block back to your factory tow hook for any hard winching, especially at an angle.
Here is my bumper/fender gap now with a 1" BL:
http://community.webshots.com/photo/...57765762ZLGMcY
Old Sep 2, 2004 | 01:59 PM
  #25
amorphous's Avatar
hey mt. goat - thanks for the install info -that's good stuff re:the hardware and and nylocks - what grade is stock w/ them? I didn't pay any attention when I opened up the box...just wanted to make sure it HAD hardware!
with the turn signals, I just have to cut, strip and splice RIGHT?
even w/1" lift and gap it looks
{Å}
Old Sep 2, 2004 | 02:18 PM
  #26
mt_goat's Avatar
{Å}
TJM sent me grade 5 bolts for the job. Grade 5 bolts are too soft IMHO. I used a long 1/2 inch drive breaker bar to tighten mine to about 110-120 ft-lb, that was as tight as I have muscles for. Put the star washers under the bolt head or nut that goes against the adjustment slots.
TJM sent me some little cheap wire splicers thingys, they worked for a few years before they failed and my turn signals quit working. I am using wire nuts now with some liquid electrical tape stuff on the end to keep water out.
Good luck and enjoy the new bumper.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
okamikai
Apr 30, 2018 10:19 PM
polo451
13
Nov 20, 2016 07:49 PM
thefishguy77
Jul 30, 2015 10:59 AM
jackiebrownia
Jul 20, 2015 09:02 AM
